To create content automatically, start by accessing Pabbly Connect. Open a new tab and type ‘pabbly.com/connect’ to reach the landing page.
Once there, if you are a new user, click on the ‘Sign Up for Free’ button. Existing users should click on ‘Sign In’. This will lead you to the Pabbly Connect dashboard, where you can create automated workflows.
Using Pabbly Connect, you can create a workflow to connect Google Sheets and Google AI Studio. Click on the ‘Create Workflow’ button to begin.
  • Choose the option to create a workflow from scratch.
  • Select the trigger application as Google Sheets.
  • Set Google AI Studio as the action application.
After setting up the trigger and action, you will have a basic workflow ready. Review your settings and make any necessary adjustments.
Next, connect Google Sheets to Pabbly Connect. You will need to add a webhook URL to capture data from Google Sheets.
To do this, go to your Google Sheets, click on ‘Extensions’, then ‘Add-ons’, and select ‘Get Add-ons’. Search for Pabbly Connect Webhooks and install it. Once installed, return to Extensions, click on Pabbly Connect, and choose ‘Initial Setup’.
  • Paste the webhook URL from Pabbly Connect in the setup box.
  • Select the trigger column as the last updated column in your sheet.
Click ‘Send Test’ to ensure the setup is successful. Once confirmed, you can start adding new rows to your Google Sheet, and the data will be captured by Pabbly Connect.
4. Integrating Google AI Studio with Pabbly Connect
Now it’s time to integrate Google AI Studio with Pabbly Connect. Click on ‘Add Connection’ and select Google AI Studio. You will be prompted to enter your API key.
To generate an API key, click on the provided hyperlink to access Google AI Studio’s API key page. Generate and copy the API key, then paste it into the Pabbly Connect setup. This will link your Google AI Studio account with Pabbly Connect.
  • Select your existing connection or create a new one.
  • Define the prompt for content generation based on your Google Sheet input.
After setting this up, you can generate blog content based on the titles added in Google Sheets. Click ‘Save and Send Test Request’ to confirm everything is working properly.
5. Publishing to Google Blogger via Pabbly Connect
Finally, connect your Google Blogger account to Pabbly Connect. Click on ‘Add New Connection’ and select Google Blogger. Sign in with your Google account to establish the connection.
Map the blog title and content generated by Google AI Studio to the respective fields in Google Blogger. Choose whether to publish the post as a draft or live.
  • Ensure you map the title and content correctly.
  • Click ‘Save and Send Test Request’ to finalize the process.
Once the test is successful, your workflow is complete. Now, whenever you add a new title in Google Sheets, Pabbly Connect will automatically generate content via Google AI Studio and publish it to your Google Blogger account.
In this tutorial, we explored how to use Pabbly Connect to automate content creation for blogs. By integrating Google Sheets and Google AI Studio, businesses can streamline their content generation process efficiently.
