1. Accessing Pabbly Connect for WhatsApp Automation
To begin automating your WhatsApp interactions, you first need to access Pabbly Connect. This platform allows you to streamline communication and collect documents efficiently.
Once you log into your Pabbly Connect account, navigate to the dashboard. Here, you will find various options to set up your integration. This is where the automation process begins.
2. Setting Up Your Chatbot Flow with Pabbly Connect
Creating a chatbot flow is essential for automating your WhatsApp messages. In Pabbly Connect, click on the “Flows” feature to access the flow builder page.
To set up your chatbot flow, follow these steps:
  • Click on the “+ Add Flow” button.
  • Name your flow to identify its purpose.
  • Select the trigger event that starts the flow.
After setting the trigger, you can add various actions that your chatbot will perform based on user responses. This makes the entire process seamless and effective.
3. Configuring Keywords and Responses in Pabbly Connect
In this step, you will configure the keywords that will trigger your chatbot. Enter keywords like “hello” and “hi” in the designated field within Pabbly Connect.
Once the keywords are set, you can create responses. Here’s how:
  • Use the text button to enter your welcome message.
  • Add quick reply buttons for options like “Upload Documents” and “Our Services”.
  • Link the responses to the respective actions in your flow.
This setup allows clients to interact with your chatbot easily and receive immediate responses based on their input.
4. Collecting Client Information via Pabbly Connect
After setting up initial responses, you can start collecting client information. Use Pabbly Connect to ask for details like full name, contact number, and email address.
To do this, follow these steps:
  • Add questions for each piece of information you need.
  • Set the format for each answer (text, number, etc.).
  • Link these questions to the next steps in your flow.
This process ensures that you gather all necessary details from clients efficiently, allowing your chatbot to function effectively.
5. Finalizing Your WhatsApp Chatbot with Pabbly Connect
Once you have configured all the necessary components of your chatbot, it’s time to finalize it. In Pabbly Connect, ensure all elements are properly linked.
To complete your setup, follow these steps:
  • Review all connections between nodes in your flow.
  • Click the “Save” button to save your flow.
  • Test your chatbot to ensure it works as expected.
Now your WhatsApp chatbot is ready to collect documents and interact with clients 24/7 through Pabbly Connect, enhancing your business efficiency.
In this tutorial, we explored how to use Pabbly Connect to automate WhatsApp interactions effectively. By following these steps, you can streamline document collection and enhance client communication.
