To integrate Pabbly with WhatsApp, first access Pabbly Connect. Visit the Pabbly website and log in or sign up for a new account. Once logged in, navigate to the Pabbly Connect dashboard, where you can create automated workflows.
After logging into Pabbly Connect, you’ll find options to add various applications. Look for the WhatsApp integration option. Here, you can start building your automation flow to manage hotel services via WhatsApp.
2. Creating a Flow in Pabbly Connect
Creating a flow in Pabbly Connect involves setting up triggers and actions. Begin by clicking on the ‘Add Flow’ button. Name your flow, such as “Hotel Booking Assistant”. This name will help you identify your automation later.
  • Select the trigger event as “Keyword Request Match”.
  • Enter keywords like ‘hi’, ‘hello’, or ‘hey’ to initiate the flow.
  • Save your trigger setup.
With the trigger set, you can now add actions. This allows you to automate responses when users interact with your WhatsApp number. Ensure that you connect the trigger to the action nodes effectively.
3. Setting Up Questions for User Interaction
Once your flow is created in Pabbly Connect, the next step is to set up a series of questions. Use the ‘Ask Question’ action to prompt users for their details. This interaction is crucial for collecting necessary information like name and booking dates.
  • First, ask for the user’s full name.
  • Then, request their phone number.
  • Next, inquire about their check-in and check-out dates.
  • Finally, ask how many guests will be staying.
By structuring your questions in this way, you can ensure that users provide all the necessary information for their hotel bookings. This detailed data collection is a key feature of using Pabbly Connect.
4. Sending Confirmation and Summary Messages
After collecting user information, the next step is to send a confirmation message. In Pabbly Connect, you can create a summary message that includes the details provided by the user. This helps in confirming their booking request.
  • Include the user’s name, check-in and check-out dates, and room type.
  • Add buttons for ‘Confirm Booking’ and ‘Edit Details’.
By incorporating these elements, your automated flow will effectively manage user bookings through WhatsApp. This functionality is what makes Pabbly Connect an essential tool for automating hotel services.
5. Testing the Integration with WhatsApp
Finally, it’s crucial to test your integration. Use your WhatsApp account to send a test message, like ‘hi’, to see if the flow activates correctly. This step ensures that your setup in Pabbly Connect works as intended.
Check if the automated responses are accurate and if the user can easily navigate through the booking process. Testing helps identify any issues before going live, ensuring a smooth experience for your customers.
Once everything is working correctly, you can confidently launch your WhatsApp integration for hotel bookings using Pabbly Connect. This setup will streamline customer interactions and improve service efficiency.
Integrating Pabbly with WhatsApp using Pabbly Connect allows hotels to automate their booking process effectively. By following the steps outlined, you can enhance customer service and streamline operations seamlessly.
