To start using Pabbly Connect for WhatsApp, navigate to Pabbly Connect by typing ‘pabbly.com/connect’ in your browser. This platform serves as the central hub for integrating various applications, including WhatsApp and Google Sheets.
Once you reach the Pabbly Connect homepage, you have options to sign up or log in. If you are new, click on ‘Sign Up for Free’ to create an account. Existing users can simply click ‘Sign In’ to access their dashboard. Pabbly Connect is designed to streamline your integration tasks efficiently.
2. Setting Up Your WhatsApp Broadcast with Pabbly Connect
After logging into Pabbly Connect, access the Pabbly Chatflow application. This is where you will manage your WhatsApp broadcasts. Click on ‘Access Now’ to go to the Pabbly Chatflow dashboard.
Once in the dashboard, ensure you have connected your WhatsApp number. If you haven’t done this, follow the tutorial available in the Pabbly resources. Next, navigate to the ‘Broadcast’ section. Here, you will create a new broadcast campaign for your flash sale message.
- Select ‘Add Broadcast’ to initiate a new campaign.
- Choose ‘Broadcast Campaign’ as the type.
- Name your campaign (e.g., “New Flash Sale”).
After naming your campaign, select the contact list to whom you want to send the message. This is where Pabbly Connect’s integration shines, allowing you to pull contacts directly from your Google Sheets.
3. Importing Contacts from Google Sheets into Pabbly Connect
To import your customer contacts from Google Sheets, you first need to download the data as a CSV file. This step is crucial as Pabbly Connect requires a CSV format for bulk uploads.
Once you have your CSV file ready, go back to the Pabbly Chatflow dashboard. Under the ‘Contacts’ section, click on ‘Add Contact’. Here, you can either add contacts one by one or upload the entire CSV file. Choose the upload option to save time.
- Upload your CSV file containing all customer data.
- Click ‘Add Contacts’ to complete the upload.
- Select the contact list for your broadcast.
After successfully uploading the contacts, you can now refine your audience by excluding any contacts you do not wish to message. This feature enhances the targeting of your WhatsApp broadcast.
4. Creating a Message Template for Your Broadcast
Before sending your broadcast, you must create a message template. In Pabbly Chatflow, navigate to the ‘Templates’ section. Click on ‘Add Template’ to create a new message.
When drafting your template, ensure it is approved by WhatsApp. You can check the status of your templates (approved, pending, rejected) in this section. For your flash sale, ensure your message is engaging and clear.
- Draft your message and save it as a template.
- Verify the approval status of your template.
- Use variables for personalization if needed.
Once your template is approved, return to the broadcast section to select your message template for the bulk WhatsApp send-off. This is another area where Pabbly Connect simplifies the process, making it user-friendly and efficient.
5. Testing and Scheduling Your WhatsApp Broadcast
Before launching your broadcast, it’s essential to test your message. In the broadcast setup, you will find an option to send a test message to your WhatsApp number. This ensures that everything looks good before sending it to your customers.
After testing, you can choose to send your broadcast immediately or schedule it for later. If you opt to schedule, select a future date and time. Make sure not to choose a past date, as this will trigger an instant send.
- Click ‘Send Test Message’ to verify your broadcast.
- Select ‘Yes’ to schedule for a later date.
- Click ‘Add Broadcast’ to finalize your setup.
Upon completion, you can track the performance of your broadcast through Pabbly Connect, where you can view stats like sent, delivered, and read messages. This level of analytics is invaluable for any business looking to optimize their communication strategy.
Using Pabbly Connect to integrate WhatsApp with Google Sheets allows businesses to efficiently broadcast messages to their customers. This guide provides a clear and concise method for setting up your WhatsApp broadcasts, ensuring you can engage your audience effectively.
