To start integrating Google Sheets with Zoho Books, you first need to access Pabbly Connect. Simply type in the URL pabbly.com/connect in your browser to reach the Pabbly Connect homepage.
Once on the homepage, you will see options to either sign in or sign up for a free account. Signing up allows you to receive 100 free tasks every month, making it a great option for new users looking to explore automation.
2. Setting Up Google Sheets with Pabbly Connect
Next, you need to set up Google Sheets as your trigger application in Pabbly Connect. Start by selecting Google Sheets as your trigger app and choose the event as “New or Updated Spreadsheet Row”.
  • Choose “New or Updated Spreadsheet Row” as the event.
After copying the webhook URL, navigate to your Google Sheets document where order data is stored. Use the “Extensions” menu to install the Pabbly Connect Webhooks add-on if you haven’t already. Once installed, set up the webhook URL in the initial setup dialog.
3. Configuring Google Sheets for Automation
To configure Google Sheets for automation with Pabbly Connect, you need to add the webhook URL you copied earlier. Go to the “Extensions” menu, select Pabbly Connect Webhooks, and then choose “Initial Setup”.
  • Paste the copied webhook URL into the designated field.
  • Set the trigger column to the last data column in your sheet.
  • Click “Submit” to complete the setup.
Once the setup is complete, send test data from Google Sheets to Pabbly Connect to ensure everything is working correctly. This will allow you to confirm that the data is being captured accurately.
4. Integrating Zoho Books with Pabbly Connect
After setting up Google Sheets, the next step is to integrate Zoho Books using Pabbly Connect. Select Zoho Books as your action application and choose the event “Create Contact”.
To establish a connection, click the “Connect” button and enter your Zoho Books domain. This is essential for building the connection between Zoho Books and Pabbly Connect. Once the connection is established, you can start mapping the fields from Google Sheets to Zoho Books.
5. Creating Invoices in Zoho Books
Finally, you will create an invoice in Zoho Books using Pabbly Connect. Select “Create Sales Invoice” as the event in Zoho Books. Use the previously established connection to proceed.
Map the necessary fields, including customer ID and pricing, directly from the data captured from Google Sheets. Once everything is set up, click “Save and Send Test Request”. This should create an invoice in your Zoho Books account, which you can verify by checking your Zoho Books dashboard.
By automating this process with Pabbly Connect, you can efficiently manage your invoicing without manual data entry, saving time and reducing errors.
In conclusion, using Pabbly Connect to integrate Google Sheets with Zoho Books allows for seamless automation of your invoicing process. This setup not only saves time but also minimizes errors, enhancing your overall workflow efficiency.
