To start automating your tasks, you need to access Pabbly Connect. Open a new tab and type in the URL pabyt.com/connect. Here, you can either sign in or sign up for a free account.
If you’re new to Pabbly Connect, signing up gives you 100 free tasks each month to explore its features. Existing users can simply sign in to access their workflows.
2. Setting Up the Trigger in Google Sheets
In this step, we will set up Google Sheets as the trigger application in Pabbly Connect. This means that every time a new entry is made in the Google Sheet, it will trigger an action.
Follow these steps to set up your trigger:
  • Select Google Sheets as your trigger application.
  • Choose the event as “New or Updated Spreadsheet Row”.
  • Click the “Connect” button to generate a webhook URL.
Copy the generated webhook URL, as it will be used to connect Google Sheets with Pabbly Connect.
3. Configuring Google Sheets to Send Data
Now that you have the webhook URL, it’s time to configure Google Sheets. Open your Google Sheet and navigate to the “Extensions” menu. Here, you will need to install the Pabbly Connect Webhook add-on.
Once installed, you will need to set up the webhook URL in the add-on:
  • Go to Extensions > Pabbly Connect Webhooks > Initial Setup.
  • Paste the webhook URL you copied earlier.
  • Specify the trigger column (e.g., D for the last data column).
Click “Submit” to finalize the setup. This allows Google Sheets to automatically send data to Pabbly Connect whenever a new entry is made.
4. Setting Up the Action to Send Notifications to Telegram
With your trigger set, it’s time to configure the action. In Pabbly Connect, select Telegram as your action application. This step allows you to send notifications to your Telegram channel whenever a new lead is added.
Here’s how to set up the action:
  • Choose the event as “Send a Text Message”.
  • Connect your Telegram account by entering the bot token.
  • Specify the chat ID where notifications will be sent.
After completing these steps, you can map the fields from Google Sheets to create dynamic messages for your Telegram notifications.
5. Testing the Integration
Now that everything is set up, it’s time to test the integration. You can do this by adding a new lead entry in your Google Sheet. Once you add the entry, Pabbly Connect will automatically capture the data and send it to your Telegram channel.
To ensure everything is working correctly:
  • Add a new row in your Google Sheet with the lead’s details.
  • Check your Telegram channel for the notification.
  • Verify that all details are correctly displayed.
If everything looks good, you’ve successfully automated the notification process using Pabbly Connect.
In this tutorial, we explored how to automate Google Sheets notifications to Telegram using Pabbly Connect. By following the steps outlined, you can streamline your workflow and receive timely updates without manual intervention.
