To generate bulk blog posts using Google Sheets, you first need to set up Pabbly Connect. Start by going to pabbly.com/connect and signing up for an account. Once logged in, navigate to the workflow page to begin setting up your automation.
In this workflow, you will configure the trigger and action applications. The first step is to select Google Sheets as your trigger application. This is essential for automating the process of generating blog posts directly from your spreadsheet.
2. Configuring Google Sheets Trigger in Pabbly Connect
After selecting Google Sheets in Pabbly Connect, choose the trigger event titled ‘New or Updated Spreadsheet Row’. This ensures that your automation will activate every time a new title and description are added to your Google Sheet.
  • Open your Google Sheet and add the titles and descriptions for your blog posts.
  • Go to the Extensions menu in Google Sheets, select Add-ons, then Get Add-ons.
  • Search for ‘Pabbly Connect Webhooks’ and install it.
Once the add-on is installed, go back to the Extensions menu and select ‘Pabbly Connect Webhooks’. Choose ‘Initial Setup’ and paste the webhook URL into the dialog box. Set the trigger column to the last data column of your sheet, typically column B, and submit the setup.
3. Sending Test Data to Pabbly Connect
With your trigger configured, the next step is to send test data to Pabbly Connect. Click on the ‘Send Test’ button within the setup to transmit the data from your Google Sheet. This confirms that the connection is established successfully.
Once the test data is sent, you should see a response in Pabbly Connect reflecting the title and description you entered in Google Sheets. This verifies that your integration is functioning correctly and ready for automation.
Next, enable the ‘Send All Events’ option in the Pabbly Connect Webhooks add-on. This will allow the automation to capture any new entries added to your Google Sheet automatically, eliminating the need for manual data submission each time.
4. Configuring OpenAI Action in Pabbly Connect
Now that your trigger is set up, you need to configure the action application, which in this case is OpenAI. Select OpenAI from the action apps in Pabbly Connect and choose ChatGPT as the action event.
To establish this connection, you will need to provide your OpenAI API key. Navigate to the OpenAI API key page to generate a new secret key if you don’t have one. Once you have your API key, enter it into Pabbly Connect to complete the connection.
  • Select the AI model you want to use, such as GPT-4.
  • Provide a prompt that instructs OpenAI on how to generate the content based on your title and description.
Utilizing the mapping feature in Pabbly Connect, you can insert the title and description dynamically into the prompt. This means that each time a new entry is made in Google Sheets, the corresponding content will be automatically generated.
5. Posting Generated Content to Facebook Page
After generating the blog content using OpenAI, the final step is to post it to your Facebook page. In Pabbly Connect, select Facebook Pages as your action application and choose ‘Create Page Post’ as the event.
Connect your Facebook account to Pabbly Connect by clicking the ‘Connect with Facebook Pages’ button. Once connected, select the page where you want to post the content. You can then map the generated content from OpenAI into the message field for your Facebook post.
  • Add the content generated by OpenAI as the message for your post.
  • Click on ‘Save and Send Test Request’ to ensure everything is set up correctly.
If successful, you will receive a positive response indicating that your blog post has been added to your Facebook page. Refresh your Facebook page to see the newly created post reflecting the generated content.
In this tutorial, we explored how to automate the process of generating bulk blog posts using Google Sheets, OpenAI, and Pabbly Connect. By following these steps, you can streamline your blogging process and enhance your social media presence effortlessly.
