To automate Google Ads leads to Google Sheets, you first need to access Pabbly Connect. Start by opening a new tab and searching for pabbly.com/connect. This will lead you to the Pabbly Connect landing page.
On the top right corner, click on ‘Sign Up for Free’. This will provide you with a free trial of Pabbly Connect. After signing up, log in to your Pabbly account and open the Pabbly Connect dashboard to begin creating your workflow.
In this step, you will set up a trigger for your workflow using Pabbly Connect. Click on the ‘Add Trigger’ button and select Google Ads as your application. Choose the event ‘New Lead Form Entry’ and then click on the ‘Connect’ button.
Once you select the event, you will be provided with a webhook URL. Copy this URL and head to your Google Ads campaign. Ensure that you have a lead form created where you can add the details you want to collect. The details should include fields like Name, Email, Phone Number, and City.
- Select the lead form you have created in Google Ads.
- Paste the copied webhook URL in the lead delivery section of your Google Ads settings.
- Enter the key provided by Pabbly Connect.
After pasting the URL and key, click on ‘Send Test Data’. This action will send a test lead to Pabbly Connect, confirming that the workflow is correctly set up. You should see the test data captured in your Pabbly Connect dashboard, indicating that the connection is successful.
3. Adding Google Sheets Action in Pabbly Connect
Next, you will add an action step to your workflow to send the captured leads to Google Sheets using Pabbly Connect. Click on the ‘Add Action’ button and select Google Sheets as the application, then choose the event ‘Add New Row’. Click on the ‘Connect’ button to proceed.
You will need to sign in to your Google account that you want to connect with Google Sheets. Allow the necessary permissions for Pabbly Connect to access your Google Sheets. After connecting, select the spreadsheet where you want to store the lead data.
- Choose the specific spreadsheet from your Google Drive.
- Map the data fields from the previous step (Name, Email, Phone Number, City) to the corresponding columns in your Google Sheets.
- Click on ‘Save and Send Test Request’ to send a test lead to your Google Sheet.
Once the test is successful, you can check your Google Sheets to see if the lead data has been added correctly. This confirms that your Pabbly Connect workflow is functioning as intended.
4. Finalizing Your Pabbly Connect Workflow
After confirming that the test data is successfully added to Google Sheets, you can finalize your workflow in Pabbly Connect. You do not need to recreate the workflow each time a new lead comes in. The automation will run in real-time.
Each time a new lead is generated in Google Ads, the data will automatically be sent to your Google Sheets without any manual input. This saves you time and ensures that all your leads are organized efficiently.
Whenever you click on ‘Send Test Data’, the latest leads will be captured and added to your Google Sheets seamlessly. This automation setup allows you to manage your leads effectively and eliminates the tedious process of manual entry.
5. Conclusion: Automate Google Ads Leads with Pabbly Connect
In this tutorial, we successfully integrated Google Ads with Google Sheets using Pabbly Connect. This no-code automation streamlines the lead collection process, making it efficient and hassle-free. You can now focus on converting leads rather than managing them manually.
By following the steps outlined, you can set up your own automated workflow, ensuring that all leads are captured and organized in real-time. Give it a try and see how Pabbly Connect can simplify your lead management process.
