To start integrating Pabbly Chatbot with WhatsApp, you first need to access Pabbly Connect. Open your browser and go to the Pabbly website, where you can find the Pabbly Connect option.
Once you are on the Pabbly Connect page, sign in with your credentials. If you are a new user, you can create an account for free. After logging in, you will be directed to the dashboard, where you can start creating your integration workflow.
2. Setting Up Pabbly Chatbot for WhatsApp Integration
In this section, you will set up your Pabbly Chatbot to respond to WhatsApp messages. Begin by navigating to the Pabbly Chatbot dashboard. Here, you will need to connect your WhatsApp number.
  • Click on the ‘Connect WhatsApp’ option.
  • Follow the prompts to link your WhatsApp account.
  • Ensure your WhatsApp is verified to receive messages.
Once your WhatsApp number is connected, you can start creating an AI assistant for handling customer queries. This assistant will utilize Pabbly Connect to manage interactions seamlessly.
3. Creating Your AI Assistant in Pabbly Chatbot
To create an AI assistant, navigate to the AI Assistant section in Pabbly Chatbot. Click on ‘Add AI Assistant’ and give your assistant a name, such as “Property Assistant”. This name will help customers identify the assistant easily.
After naming your assistant, you will be prompted to set up AI instructions. Choose the type of assistant you want to create, such as a customer support agent. This setup is crucial as it defines how Pabbly Connect will facilitate responses to customer inquiries.
  • Input specific instructions that the AI should follow.
  • Set the response temperature to control the creativity of replies.
  • Select the AI model from OpenAI that you want to use.
Once configured, you can save your AI assistant. This assistant will now be ready to interact with customers on WhatsApp, powered by Pabbly Connect.
4. Setting Up the Knowledge Source for Your Assistant
The next step is to upload a knowledge source that your AI assistant will use to provide accurate responses. You can create a Google Doc containing all relevant information about your business and download it as a PDF or TXT file.
After preparing your document, return to the Pabbly Chatbot dashboard. Here, you will find an option to upload your knowledge source. This is essential for ensuring that the AI assistant has the necessary information to answer customer queries effectively.
  • Click on the ‘Upload Knowledge Source’ button.
  • Select the PDF or TXT file you downloaded.
  • Confirm the upload to finalize the setup.
With the knowledge source uploaded, your assistant is now equipped to provide information based on the content of your document, all managed through Pabbly Connect.
5. Activating Your AI Assistant for Customer Queries
Now that your AI assistant is set up and has a knowledge source, it’s time to activate it for customer queries. Go back to the settings in your Pabbly Chatbot dashboard. Here, you can enable the AI auto-reply feature.
To activate the assistant, click on ‘Inbox Settings’ and enable the AI auto-reply. This will allow the assistant to respond instantly to any incoming messages on WhatsApp, eliminating the need for manual responses.
  • Select your AI assistant from the dropdown menu.
  • Save the settings to activate the assistant.
  • Test the assistant by sending a message on WhatsApp.
Your AI assistant is now fully functional and can handle customer queries automatically, thanks to the seamless integration facilitated by Pabbly Connect.
In conclusion, integrating Pabbly Chatbot with WhatsApp using Pabbly Connect allows businesses to automate responses to customer queries effectively. This setup not only saves time but also enhances customer satisfaction.
