1. Accessing Pabbly Chatflow for WhatsApp Automation
To start with Pabbly Chatflow, first, access the platform by typing in the URL: Pabbly Chatflow at pabby.com/chatflow. You will be greeted by the landing page where you can sign up for an account. Once registered, you will land on your dashboard, ready to create your WhatsApp automation.
Before proceeding, ensure you link your WhatsApp number with your Pabbly account. This is essential for sending messages through the platform. If you need assistance, refer to the video tutorial provided in the description.
2. Creating Broadcast Messages in Pabbly Chatflow
In this section, we will create an engaging broadcast message using Pabbly Chatflow. Start by selecting the “Templates” option from the left-hand menu in your dashboard. This will direct you to the templates page where you can create your offer message.
- Select the “Broadcast” option from the left menu.
- Choose “Broadcast Campaign” as the type.
- Name your broadcast, e.g., “Travel Agency Offer”.
- Select your audience from existing contact lists or upload a CSV file.
After selecting the audience, you can choose the message type. For this example, use the pre-approved template message you created earlier. Once everything is set, you can either send the broadcast immediately or schedule it for a later date.
3. Building a Chatbot with Pabbly Chatflow
Next, we will create a chatbot using Pabbly Chatflow to interact with customers. Navigate to the “Flows” section in the left-hand menu. Here, you will create a new flow that will initiate when users interact with the broadcast message.
Set your trigger to “Template Selected”. This means that when a user clicks a button in your broadcast, the chatbot will start. You can create various options for user responses, such as “Plan My Next Trip” or “Talk to AI Expert”. Each option will lead to specific actions and responses.
- Use the “List Node” to display options for users.
- Add media elements to provide images and details about travel packages.
- Incorporate “Ask Question” nodes to gather user information.
This chatbot will guide users through their inquiries, collecting information like travel dates and number of travelers. Ensure you personalize responses using the contact custom fields.
4. Saving Data to Google Sheets via Pabbly Connect
Now, let’s integrate Pabbly Chatflow with Google Sheets using Pabbly Connect to save customer data. This step is crucial for managing leads effectively. In your flow, use the “API Request Node” to set up a POST request to your Google Sheets.
In the API Request Node, enter the webhook URL provided by Pabbly Connect. This URL will facilitate the data transfer from your chatbot to Google Sheets. Specify the parameters for the data you wish to save, such as the user’s name, travel package, and email address.
Once the data is captured, it will automatically populate in your Google Sheet, allowing for easy access and management. This integration ensures that all leads collected via WhatsApp are stored systematically.
5. Interacting with the AI Assistant in Pabbly Chatflow
The final step is to set up an AI assistant within Pabbly Chatflow to handle customer queries. When users select the “Talk to AI Expert” button, they will be directed to your AI assistant. This assistant can answer questions based on a knowledge base you provide.
To create your AI assistant, navigate to the “Assistant” section in the left menu. Here, you can define responses based on common customer inquiries. The assistant will utilize the knowledge base to provide accurate information, enhancing customer experience.
- Set up welcome messages for initial interactions.
- Ensure the assistant can access the knowledge base for relevant answers.
- Test the assistant to ensure it responds accurately to user queries.
This AI assistant will significantly reduce the workload on customer service, allowing for seamless communication with clients.
In this tutorial, we explored how to automate WhatsApp communication using Pabbly Chatflow. By integrating various features like broadcast messages, chatbots, and AI assistants, you can create a comprehensive customer engagement strategy. Pabbly Chatflow simplifies the process, ensuring efficient lead management and customer interaction.
