1. Introduction to Automating WhatsApp Feedback with Pabbly Connect
In this tutorial, we will explore how to use Pabbly Connect to automate WhatsApp feedback collection. This process allows businesses to gather customer reviews seamlessly after a purchase.
Using Pabbly Connect, we will integrate Google Sheets to capture customer responses and send automated WhatsApp messages. This setup is user-friendly and requires no coding skills.
2. Setting Up Google Sheets with Pabbly Connect
To start, you need to create a Google Form for collecting customer data. This form will feed responses directly into Google Sheets, which will be linked to Pabbly Connect.
Follow these steps to connect Google Sheets with Pabbly Connect:
  • Open Google Sheets and create a new spreadsheet.
  • Link your Google Form to this spreadsheet by navigating to “Responses” and selecting “Link to Sheets”.
  • Install the Pabbly Connect Webhooks add-on from the Google Workspace Marketplace.
After completing these steps, your Google Sheets will be ready to capture customer feedback, which will be processed through Pabbly Connect.
3. Configuring Webhook in Pabbly Connect
Next, we will set up the Webhook in Pabbly Connect to receive data from Google Sheets. This step is crucial for capturing customer responses automatically.
To configure the Webhook:
  • In Pabbly Connect, create a new workflow and select “Webhook” as the trigger application.
  • Go back to Google Sheets, navigate to the Pabbly Connect Webhooks settings, and paste the Webhook URL.
Once configured, every time a customer submits the Google Form, their data will be sent to Pabbly Connect via the Webhook.
4. Sending Automated WhatsApp Messages Using Pabbly Chatbot
After setting up the Webhook, the next step is to send automated WhatsApp messages using Pabbly Chatbot. This feature allows you to engage with customers immediately after they complete their purchase.
Here’s how to set it up:
  • Add an action step in Pabbly Connect and select Pabbly Chatbot as the application.
  • Choose the action event as “Send Message”.
  • Map the customer’s phone number from the previous step to the message action.
This setup ensures that customers receive a personalized message thanking them for their purchase and requesting feedback through WhatsApp.
5. Testing the Integration and Conclusion
Finally, it’s essential to test the entire integration to ensure everything works smoothly. Use the Google Form to submit a test response and check if the automated WhatsApp message is delivered correctly through Pabbly Connect.
To summarize:
  • Ensure all steps are correctly configured in Pabbly Connect.
  • Check the response in Google Sheets and verify the WhatsApp message.
  • Make adjustments if necessary to improve the workflow.
Using Pabbly Connect to automate WhatsApp feedback collection not only saves time but also enhances customer engagement, leading to more reviews and better service.
In conclusion, this tutorial demonstrates how to effectively use Pabbly Connect to automate WhatsApp feedback for your business. By following these steps, you can easily gather valuable customer insights and improve your services.
