1. Accessing Pabbly Connect for Hotel Automation
To begin using Pabbly Connect for your hotel business, first navigate to the Pabbly Chartflow website. This platform allows you to automate responses and manage inquiries seamlessly through WhatsApp.
If you are a new user, click on the ‘Sign Up Free’ option to get started. Existing users can simply sign in. After signing in, you will be directed to the Pabbly Chartflow dashboard where all your WhatsApp numbers can be managed.
2. Creating Your AI Assistant with Pabbly Connect
Once you are in the Pabbly Chartflow dashboard, the next step is to create your AI assistant. Click on the ‘Add Assistant’ button and give your assistant a name that reflects its purpose, such as “AI Booking Assistant for Hotels”.
- Select the assistant type as “AI Agent”.
- Set the temperature to 0.5 for balanced responses.
- Choose the model provider as OpenAI and select GPT-4 Mini.
This setup allows your assistant to respond accurately to guest inquiries, simulating human-like interactions. Customizing these settings is crucial as it defines how the assistant behaves.
3. Uploading Knowledge Base for Accurate Responses
For the AI assistant to provide accurate replies, you need to upload a knowledge base file. This file serves as the information bank for your assistant, containing necessary details about your hotel.
Ensure your knowledge base file is in PDF format and less than 90 MB. Once prepared, upload it by clicking the ‘Add New File’ option and dragging your file into the upload area. After uploading, select the file and click ‘Insert’.
- The knowledge base should include FAQs, room details, and pricing.
- Make sure the content is specific to your hotel operations.
This knowledge base ensures that your AI assistant can provide tailored responses to inquiries, enhancing customer satisfaction.
4. Configuring Assistant Settings in Pabbly Connect
After uploading the knowledge base, configure your assistant settings. This includes setting up the header and footer messages, which will be displayed during conversations with guests.
Enable the toggle for the header message if you wish to send a welcome message. Additionally, set up stop keywords that will halt the assistant’s responses if needed. You can also define retry attempts for the assistant to ensure it tries multiple times to respond correctly.
- Header messages can include greetings or introductions.
- Footer messages should thank users or provide additional information.
These settings allow for a more personalized interaction, making guests feel valued and understood.
5. Finalizing Your AI Assistant Setup with Pabbly Connect
Once all settings are configured, enable your assistant and save the setup. This action activates your AI assistant, allowing it to start responding to inquiries immediately.
To embed the assistant on your website, click the ‘Embed’ button to get the necessary code. This code can be pasted into your website, enabling guests to interact with your assistant directly.
By utilizing Pabbly Connect, your hotel can now respond to inquiries in real-time, providing potential guests with instant information and enhancing the booking process.
In conclusion, using Pabbly Connect to automate hotel inquiries through WhatsApp AI dramatically improves customer engagement. This setup allows for instant replies, enhancing the booking experience and increasing customer satisfaction.
