To create a WhatsApp bot that automatically books appointments, you first need to set up Pabbly Connect. This platform will serve as the integration hub for your WhatsApp bot and appointment booking system.
Start by signing up for a free account on Pabbly Connect. Once logged in, navigate to the dashboard where you can create a new workflow. This is where you’ll define how your WhatsApp bot will interact with users and manage appointment bookings.
2. Creating Your WhatsApp Bot with Pabbly Connect
Creating the WhatsApp bot involves several steps within Pabbly Connect. You’ll need to set up triggers and actions that guide the conversation flow. Begin by selecting the option to create a new flow.
- Click on the “Add Flow” button.
- Name your bot, e.g., “Health Appointment Bot”.
- Set the trigger event to “Template Selected”.
After setting up the trigger, you can add the first message that users will receive when they interact with your bot. This message should welcome them and ask for their full name.
3. Collecting User Data for Appointment Booking
Once your bot is set up, the next step is to collect user data. Using Pabbly Connect, you can create custom fields to store the information received from users.
For instance, after asking for the user’s full name, the bot should prompt for their phone number, email address, age, and type of consultation. Each of these responses can be saved in custom fields within Pabbly Connect.
- Ask for the phone number and save it in a custom field.
- Request the email and age, saving each in their respective fields.
- Inquire about the type of consultation, e.g., skin consultation.
This structured approach ensures that all necessary data is collected efficiently through the WhatsApp bot.
4. Finalizing Appointment Details with Pabbly Connect
After collecting user data, you can finalize the appointment details using Pabbly Connect. The bot should ask users for their preferred date and time for the appointment.
In this step, you can configure the date and time fields to allow users to choose their preferred slots. Make sure to set up validation to ensure that users select valid dates and times.
- Drag and drop the date and time fields into your flow.
- Set the available days for booking appointments.
- Configure the time slots for each day.
Once the user selects their appointment details, all information will be saved in Pabbly Connect, ready for confirmation.
5. Sending Confirmation Messages via WhatsApp
The final step in your WhatsApp bot setup is to send a confirmation message to users. With Pabbly Connect, you can personalize this message by including all the details the user provided.
For example, your confirmation message could say, “Thank you, [User’s Name], your appointment has been booked for [Date] at [Time].” This personalized touch enhances user experience and builds trust.
After saving your bot configuration, you can test the flow to ensure everything works as expected. If any issues arise, you can easily modify the flow using Pabbly Connect.
Using Pabbly Connect, you can create an efficient WhatsApp bot for automatic appointment bookings. This setup not only saves time but also enhances customer engagement and satisfaction.
