To start using Pabbly Connect, open a new tab in your browser and type pabbly.com/connect. Press the Enter key, and you will be directed to the Pabbly Connect landing page.
If you are a new user, click on the “Sign Up for Free” button to create your account. Existing users can click on the “Sign In” button to access their accounts. Pabbly Connect is a powerful tool that allows you to automate tasks between multiple applications, including Lindin and WhatsApp.
Once logged into Pabbly Connect, navigate to the dashboard and click on “Create Workflow”. This action will allow you to set up the automation for sending WhatsApp messages whenever a new lead is generated from Lindin.
In the workflow builder, provide a name for your workflow, such as “Connect Lindin Leads to WhatsApp”. After entering the name, click on “Create” to proceed. Your workflow setup is now ready for the next steps.
- Click on the “Add Trigger” button to select Lindin as the trigger application.
- Choose the event that will trigger the workflow, such as “New Lead”.
- Connect your Lindin account to Pabbly Connect by providing your login credentials.
After setting up the trigger, you are ready to capture lead details from Lindin and send them to WhatsApp.
3. Generating a Test Lead from Lindin
To test your workflow, generate a test lead from your Lindin account. Click on the “Apply Now” button in your Lindin ads to simulate a new lead generation. Fill in the required details, such as your email address and contact number.
Once you submit the form, Pabbly Connect will automatically capture the lead details, including the customer’s email ID and phone number. This information will be used to send a WhatsApp message.
- Ensure that the contact number is in the correct format, including the country code.
- Submit the form to trigger the automation.
Once the lead is generated, you will receive a response in Pabbly Connect confirming that the lead details have been captured successfully.
4. Sending WhatsApp Message Using Pabbly Connect
After capturing the lead details, the next step is to send a WhatsApp message. In the workflow, click on “Add Action” and select Pabbly Chatflow as the action application. This integration allows you to send messages directly to WhatsApp.
To connect your Pabbly Chatflow account, you will need to provide an API token. Navigate to your Chatflow account settings, copy the API token, and paste it into Pabbly Connect.
- Map the contact number field from the previous step to the recipient field in Chatflow.
- Draft your WhatsApp message, including the customer’s name for personalization.
Once everything is set up, click on “Save and Send Test Request” to send a test message to the generated lead. You should see a confirmation that the message was sent successfully.
5. Conclusion
By following this tutorial, you can seamlessly integrate Lindin with WhatsApp using Pabbly Connect. This automation allows you to send instant follow-up messages to new leads without any manual effort. With just a few simple steps, you can enhance your lead engagement and improve your marketing efficiency.
Utilizing Pabbly Connect for such integrations not only saves time but also ensures that you never miss an opportunity to connect with potential customers.
