To start integrating WooCommerce with Slack, first access Pabbly Connect by visiting the official website. Sign in with your existing account or sign up for a free trial to explore its features.
Once logged in, you will see various Pabbly applications. Click on the Pabbly Connect option to access the dashboard where you can create your workflows.
In this section, we will create a new workflow in Pabbly Connect. Click on the “Create Workflow” button to begin. You will need to name your workflow and select a folder to organize it.
- Choose a descriptive name for your workflow.
- Select a folder, such as “All Automations”.
- Click on “Create” to proceed.
After creating the workflow, you will see a box prompting you to select your trigger application. Since we want to trigger the workflow based on new WooCommerce orders, select WooCommerce as the trigger application.
3. Setting Up WooCommerce as the Trigger
To set up WooCommerce as the trigger in Pabbly Connect, choose the event “New Order Created”. This event will initiate the workflow whenever a new order is placed in your WooCommerce store.
Next, Pabbly Connect will provide you with a webhook URL. This URL acts as a bridge between WooCommerce and Pabbly Connect. Copy this URL and head over to your WooCommerce settings.
- Go to WooCommerce settings and select “Advanced”.
- Click on “Webhooks” and then “Add Webhook”.
- Paste the webhook URL and set the status to active.
After saving the webhook, return to Pabbly Connect and click on “Recapture Webhook Response” to ensure the setup is working correctly.
4. Testing the Integration with WooCommerce
Once the webhook is set up, it’s time to test the integration. Create a new order in your WooCommerce store to check if Pabbly Connect captures the order details correctly. Enter dummy details and complete the checkout process.
After placing the order, return to Pabbly Connect to see if the webhook response has been captured. You should see the order details, confirming that the connection is successful.
- Verify that the order total, product name, and customer details are displayed correctly.
- If you see the details, the integration is functioning as expected.
With this confirmation, your WooCommerce store is now effectively connected to Pabbly Connect for order notifications.
5. Sending Notifications to Slack
Now that WooCommerce is set up as a trigger, the next step is to send notifications to Slack. In Pabbly Connect, select Slack as your action application and choose the event “Send Channel Message”.
Connect your Slack account by entering the necessary permissions. After connecting, you will need to specify the channel ID where you want the order notifications to appear.
- Enter the channel ID for WooCommerce orders.
- Compose your message, e.g., “Hello team, we have received a new order”.
- Map the order details dynamically to ensure they update with each new order.
Finally, save your settings and send a test message to verify that notifications are being sent correctly to your Slack channel. Once confirmed, your integration is complete!
In this tutorial, we’ve successfully integrated WooCommerce with Slack using Pabbly Connect. This automation ensures that your team is promptly notified of new orders, streamlining your workflow and improving communication.
