To begin integrating your website form with Slack, you need to access Pabbly Connect. Visit the Pabbly website and sign in to your account. If you are a new user, you can sign up for free, which gives you access to 100 tasks monthly to test the platform.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create workflows that automate tasks between applications. This is where you’ll set up the connection between your website form and Slack using Pabbly Connect.
Now that you are in the Pabbly Connect dashboard, it’s time to create a new workflow. Click on the ‘Create Workflow’ button and name it “Get Instant Slack Alert for Every Website Lead”. Select a suitable folder, such as “Forms Automation”, to organize your workflow.
  • Click on ‘Create’ to finalize your workflow setup.
  • In the trigger application, select ‘Webhook by Pabbly’.
  • Choose ‘Select Catch Webhook’ as the trigger event.
This setup will ensure that whenever there is a new form submission on your website, it automatically triggers a notification to your Slack channel through Pabbly Connect.
3. Connecting Your Website Form to Pabbly Connect
Next, you need to connect your website form to Pabbly Connect. After selecting the Webhook trigger, a unique webhook URL will be generated. Copy this URL and paste it into your website form’s code, replacing any existing webhook URL.
Once the webhook is set up, go back to your Pabbly Connect workflow and click on ‘Test Webhook’. This will allow you to capture the response from your form submission. To do this, perform a test submission on your website form.
4. Setting Up Slack Notifications
After successfully capturing the webhook response, the next step is to set up notifications in Slack. In the action application, select Slack and choose the action event as ‘Send Channel Message’. This will allow you to send a message to your designated Slack channel whenever there is a new lead.
  • Connect your Slack account by clicking on ‘Connect with Slack’.
  • Enter the channel ID where you want to send notifications.
  • Map the fields from your webhook response to the message format.
Using Pabbly Connect, you can easily customize the message to include details like the lead’s name and email, ensuring your team is always updated with new leads.
5. Testing and Saving Your Workflow
Once you’ve mapped the fields and configured the message, it’s time to test the workflow. Click on ‘Save and Send Test Request’ to send a test notification to your Slack channel. Check your Slack channel to ensure the message appears as expected.
If everything looks good, save your workflow. Now, every time a new form submission occurs on your website, Pabbly Connect will automatically send a notification to your Slack channel with the lead details.
In this tutorial, we explored how to integrate your website form with Slack using Pabbly Connect. By following these steps, you can ensure that your team receives instant notifications about new leads, streamlining your communication process. This automated workflow not only saves time but also enhances the efficiency of your lead management system.
