To start integrating LinkedIn with Slack, you first need to access Pabbly Connect. Open your browser and go to pabbl.com/connect. If you are a new user, click on the “Sign Up for Free” option in the top right corner to create an account.
Once registered, you will receive 100 free tasks every month, allowing you to test Pabbly Connect and create your automation without any cost. This is a great way to explore how Pabbly Connect can streamline your notifications from LinkedIn to Slack.
2. Setting Up Your Workflow in Pabbly Connect
Now that you have accessed Pabbly Connect, navigate to the workflow builder. This is where you will create the automation. Click on “Add Trigger” to begin setting up your integration.
- Select LinkedIn as your trigger application.
- For the event, choose “Lead Notifications”.
- Connect your LinkedIn account by clicking on “Connect”.
This step is crucial as it establishes the connection between LinkedIn and Pabbly Connect. After connecting, you will be prompted to choose your sponsored account. If no options appear, refresh the fields to see your accounts.
3. Capturing the Webhook Response
Once your LinkedIn account is connected, click on “Send Test Request” to capture the webhook response. You will need to submit a test lead from LinkedIn to see if the connection works.
To do this, fill out the lead form with your email and phone number, then click “Submit”. After submitting, return to Pabbly Connect and wait for the webhook response. If you encounter a timeout error, simply click on “Capture Webhook Response” again and resubmit the lead form.
4. Notifying Your Team on Slack
Once the webhook response is successfully captured, it’s time to set up Slack notifications. Click on “Add New Action Step” and search for Slack as your action application.
- Choose “Send Channel Message” as the event.
- Connect your Slack account by clicking on “Connect”.
- Select the channel where you want to receive the notifications.
After setting up the connection, you can customize the message that will be sent to your Slack channel. Use the mapping feature in Pabbly Connect to insert lead details dynamically, ensuring your team receives accurate information with each new lead.
5. Testing and Using the Integration
After configuring the Slack notification, it’s essential to test the integration. Click on “Save and Send Test Request” to verify that the message is sent to your selected Slack channel. You should see a confirmation message indicating that the message was successfully sent.
Once confirmed, your automation is complete. Now, every time you receive a new lead from LinkedIn, your team will receive an instant notification on Slack through Pabbly Connect. This integration ensures that your team stays updated in real-time, enhancing communication and efficiency.
In this tutorial, you learned how to integrate LinkedIn with Slack using Pabbly Connect. This powerful automation allows for instant lead notifications, improving team communication and response times. Start using Pabbly Connect today to streamline your workflows and enhance productivity.
