To start automating your Pinterest pins, you need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect. This will take you to the Pabbly Connect homepage where you can sign up or log in.
New users can sign up for free and receive 300 tasks monthly. Existing users can simply log in. Once logged in, click on “Access Now” under Pabbly Connect to enter the dashboard and begin creating your workflow.
After entering the Pabbly Connect dashboard, click on “Create from Scratch” to build a new workflow. This option allows you to customize your automation process efficiently using Pabbly Connect.
When prompted, describe your workflow. For example, specify that on certain days, OpenAI should generate a title and an image for your Pinterest pin. Then, select the appropriate trigger for your workflow. Here’s how to set it up:
- Choose “Schedule Workflow” as the trigger.
- Select the action as “ChatGPT” for OpenAI.
- Add a second action step to generate an image using “GPT Image One”.
Now, approve and create the workflow to receive your workflow link.
The next step in using Pabbly Connect is setting up your trigger. You can select how often you want the automation to run, such as on specific days of the week at a set time.
Choose the days and set the time, for example, 11:00 AM. Once you click save, you will receive a confirmation that your trigger has been successfully set up. This means your workflow is now ready to activate at the specified times.
4. Generating Title and Image Using OpenAI
With your trigger set, the next step is to generate a title and image for your Pinterest pin using OpenAI through Pabbly Connect. First, you need to create a connection to OpenAI by providing an API token.
To obtain the token, click on the hyperlink in the Pabbly interface that directs you to your OpenAI account’s API keys. Create a new secret key and copy it back to Pabbly Connect. For the AI model, select GPT-5 and input your prompt for generating a title. After saving, you will receive a successful response with the generated title.
Next, repeat the process to generate an image. Map the data from the title generated in the previous step into the image generation request. Select the appropriate parameters and save the request to receive a URL for the generated image.
5. Creating a New Pin on Pinterest
Finally, it’s time to create a new pin on your Pinterest account using the title and image generated through Pabbly Connect. Start by building a new connection to Pinterest.
After granting access, select your Pinterest board and map the title and image URL generated earlier. Once you save and send the request, you will receive a successful response confirming that the new pin has been created.
To verify, refresh your Pinterest account to see the newly created pin with the title and image provided by OpenAI, showcasing the effectiveness of your automation.
Using Pabbly Connect, you can easily automate the process of generating and posting Pinterest pins using OpenAI. This tutorial demonstrated how to set up the integration step-by-step, ensuring a seamless workflow.
