To start generating unique articles automatically, you need to access Pabbly Connect. First, open your browser and go to the Pabbly Connect website. If you are a new user, click on ‘Sign Up for Free’ to create an account and receive 100 free tasks every month.
If you already have an account, simply click on ‘Sign In’. After logging in, you will be directed to the Pabbly Connect dashboard, where you can access all the applications available for integration.
Once you are in the dashboard of Pabbly Connect, you can begin creating a new workflow. Click on ‘Create Workflow’ and choose to build from scratch. You will be prompted to name your workflow, which could be something like “Daily Article Generation”.
- Select the trigger app as Google DS.
- Choose the action event as “Generate Content”.
- Set the schedule for the workflow to run daily.
After setting up the trigger, you can now configure the action steps for generating articles. The integration will allow you to generate both the title and content of the articles automatically.
3. Configuring AI Tools with Pabbly Connect
In this step, you will configure the AI tool you want to use for content generation. Within Pabbly Connect, select the AI tool, such as Gemini, to generate your article content. You will need to provide an API key from your AI tool account.
To obtain the API key, navigate to your AI tool’s settings and copy the key. Then, return to Pabbly Connect and paste the key in the designated field. This will allow Pabbly Connect to communicate with the AI tool and generate content based on the prompts you provide.
- Enter a relevant prompt for article generation.
- Select the model version you wish to use.
- Click on “Save” to finalize the configuration.
Once configured, you can test your setup to ensure that the AI tool generates the expected article content.
4. Saving Generated Articles to Google Docs
After generating the article content, the next step is to save it in your Google Docs account. Within Pabbly Connect, add another action step and select Google Docs as the application. Choose the action event as “Create Document”.
You will need to sign in to your Google account and grant Pabbly Connect permission to access your Google Docs. After successfully connecting, specify the document name using the title generated by the AI tool. This ensures that each article is saved with a unique name.
5. Finalizing the Automation Process
Once you have set up the action step to save the article in Google Docs, review your entire workflow in Pabbly Connect. Ensure that the trigger and action steps are configured correctly. You can test the workflow to see if it generates an article and saves it as intended.
If everything looks good, click on “Save” to finalize your automation. With this setup, Pabbly Connect will automatically generate and save unique articles every day at the scheduled time, allowing you to focus on other important tasks.
Using Pabbly Connect, you can effortlessly automate the process of generating unique articles daily. This integration with Google DS and AI tools streamlines your content creation process, saving you time and effort.
