To start integrating YouTube with WhatsApp using Pabbly Connect, first, visit pabbly.com/chatflow in your browser. This will direct you to the Pabbly Chat Flow homepage, where you can either sign up for a free trial or log in if you are an existing user.
Once logged in, navigate to the “All Pabbly Applications” section. Here, click on “Access Now” under Pabbly Chat Flow. This will take you to the Pabbly Chat Flow dashboard, where you can set up your WhatsApp broadcasting.
2. Setting Up WhatsApp Broadcast using Pabbly Connect
To initiate a WhatsApp broadcast, you need to locate the “Broadcast” feature within Pabbly Chat Flow. Before proceeding, ensure that you have a WhatsApp number linked to your Pabbly Chat Flow account. You can view your templates under the templates section.
  • Access the “Broadcast” section in Pabbly Chat Flow.
  • Select the option to create a new broadcast.
  • Choose whether to upload a CSV file or use existing contacts.
After selecting to create a new broadcast, you will need to name your broadcast, choose your audience, and decide on the type of message to send. This can be a template or a regular message, depending on your needs.
3. Uploading CSV Data with Pabbly Connect
When prompted, you can upload a CSV file containing your contact information. This is crucial for sending messages to a broader audience without manually entering each contact. Ensure your CSV is formatted correctly to avoid errors during the import.
Once your CSV is uploaded, click on the import button. This will create a separate contact list for your broadcast. If you prefer, you can also select an existing contact list from your Pabbly Chat Flow account.
4. Configuring Message Options in Pabbly Connect
After setting up your audience, you will need to configure your message options. In this step, you can choose to use a pre-approved message template or write a new message. If you select a template, ensure it meets the guidelines set by WhatsApp.
You can also add variables to personalize your messages. After finalizing your message, you can test it by sending a trial message to your own WhatsApp number. This ensures that everything looks correct before sending it to your audience.
  • Choose between a pre-approved template or a custom message.
  • Add any necessary variables for personalization.
  • Send a test message to ensure accuracy.
Once you are satisfied with the test message, you can proceed to schedule the broadcast or send it immediately, depending on your preference.
5. Scheduling and Sending Broadcasts with Pabbly Connect
To schedule your broadcast, select the date and time you want the message to be sent. Make sure to choose a future date; otherwise, the message will be sent immediately. You can also enable automatic retries for any failed messages.
After configuring all settings, click on the “Create Broadcast” button. This will schedule your WhatsApp broadcast successfully. You can monitor the performance of your broadcast, including message delivery statistics, once it is sent.
In conclusion, using Pabbly Connect simplifies the process of integrating YouTube with WhatsApp and allows for effective communication with your audience through broadcasting.
In this tutorial, we explored how to effectively use Pabbly Connect to integrate YouTube, Pabbly Chat Flow, and CSV for WhatsApp broadcasting. This process enhances communication efficiency and streamlines outreach efforts.
