To start using Pabbly Connect, visit pabby.com and log in to your account. After logging in, navigate to the Pabbly Connect dashboard where you can create a new workflow.
Once on the dashboard, select the option to create a workflow from scratch. Name your workflow according to your project needs, such as “RSS to WordPress Automation”. This setup will facilitate the integration between RSS feeds, OpenAI, and WordPress using Pabbly Connect.
2. Setting Up RSS Trigger in Pabbly Connect
In this step, you will set the RSS feed as the trigger application in Pabbly Connect. Select the RSS by Pabbly application and choose the event as “New Item in Feed”. This event starts the automation whenever new content is available in the RSS feed.
  • Enter the feed URL from the Indian Express education section.
  • Select the default filter type for capturing new items.
  • Save and send a test request to ensure the connection works.
After clicking on “Save and Send Test Request”, check if you receive the latest news item from the RSS feed. If successful, this confirms that the trigger is set up correctly in Pabbly Connect.
3. Configuring OpenAI Action in Pabbly Connect
Next, you will configure OpenAI as the action application in Pabbly Connect. Select OpenAI and choose the action event “Chat GPT”. This action will generate blog content based on the news captured from the RSS feed.
To connect OpenAI, you need to enter your API token. If you do not have an existing connection, create a new one by generating an API key from the OpenAI dashboard. Ensure you select the appropriate permissions and expiry date for the key.
4. Mapping Data to WordPress in Pabbly Connect
After generating the blog content using OpenAI, the next step is to post this content to WordPress. In Pabbly Connect, add another action step and choose WordPress as the application. Select the action event “Create a Post” to publish the blog content directly.
  • Enter the WordPress base URL without the path.
  • Input your WordPress credentials to connect.
  • Map the title and content from OpenAI’s response to the WordPress post fields.
After mapping the required fields, click on “Save and Send Test Request” to publish the blog post. This will create a new post in your WordPress dashboard, showcasing the latest content generated from the RSS feed using Pabbly Connect.
5. Conclusion
In this tutorial, we explored how to automate the process of converting RSS feeds into blog posts using Pabbly Connect. By integrating RSS, OpenAI, and WordPress, you can keep your audience engaged with fresh content effortlessly.
This integration not only saves time but also ensures your social media platforms are updated with the latest information automatically. Start leveraging Pabbly Connect today to streamline your content creation process!
