To start automating your LinkedIn posts, the first step is to access Pabbly Connect. Open your preferred browser and navigate to pabbly.com/connect. Here, you will find options to sign up or log in.
If you are a new user, click on the “Sign Up for Free” button to create an account. Existing users can simply log in. Pabbly Connect offers 300 tasks every month for free, allowing you to explore its features effectively.
Once logged in, you will see all Pabbly applications. Click on “Access Now” under Pabbly Connect to reach the dashboard. To create a new automation, you need to set up a workflow.
  • Select the “Quick Builder” option for a faster setup.
  • Understand the two principles: Trigger (when this happens) and Action (do this).
With Pabbly Connect, you can have one trigger and multiple actions, making your automation flexible and efficient. Now, let’s set up the trigger for daily automation.
3. Setting Up the Trigger for Daily Automation
To automate your LinkedIn posts daily, select “Schedule by Pabbly” as your trigger. This will allow you to define how often the workflow should run. Choose “Every Day” and set the time, for example, 12:00 PM.
After selecting your preferences, click on “Save”. You will receive a confirmation message indicating that your automation is scheduled successfully. This setup ensures that your automation runs daily without manual intervention.
4. Integrating AI Tools with Pabbly Connect
Next, we will connect an AI tool to generate content for your LinkedIn posts. You can use tools like Gemini or Perplexity AI. For this, you will need an API key from your Google AI Studio account.
  • Click on the provided hyperlink to access Google AI Studio.
  • Select “Create API Key” if you don’t have an existing key.
Once you have your API key, return to Pabbly Connect and input the key into the designated field. Next, provide a relevant prompt to guide the AI in generating your LinkedIn post content.
5. Posting to LinkedIn Using Pabbly Connect
After generating the content, it’s time to share it on LinkedIn. In Pabbly Connect, set up a new action step to connect to your LinkedIn account. You will need to provide your LinkedIn credentials for access.
Once connected, select the author and map the content generated by the AI into the post field. This mapping allows you to dynamically insert the generated content into your LinkedIn post, ensuring fresh content every time.
Finally, click on “Save and Send Test Request” to verify that your post is shared successfully. You should see the new post appear on your LinkedIn account instantly, confirming that your automation is working as intended.
By following these steps, you can automate your LinkedIn posts using Pabbly Connect, ensuring consistent and timely content delivery. This integration not only saves time but also enhances your digital marketing efforts efficiently.
