1. Accessing Pabbly Connect for Blog Automation
To start automating your blog posts, first access Pabbly Connect. Open a new tab and type in pably.com/connect. Once you hit enter, the landing page for Pabbly Connect will appear.
If you are a new user, click on “Sign Up for Free” to create an account and get 100 free tasks every month. Existing users can simply click on “Sign In” to access their dashboard.
After logging into Pabbly Connect, the next step is to create a new workflow. Click on the “Create Workflow” button. You can either build from scratch or use the quick workflow builder.
- Click on “Create Workflow”.
- Choose to build from scratch or use the quick builder.
- Name your workflow according to your needs.
Once named, you’ll be prompted to define what you want to automate. This is where you can specify that you want to schedule posts from Google AI Studio to Google Blogger.
3. Scheduling Blog Posts with Pabbly Connect
In this section, you will set up the scheduling for your blog posts. With Pabbly Connect, you can decide how often to post your blogs. For example, you can choose to post daily, weekly, or at specific intervals.
- Select the frequency for posting: daily, weekly, or custom intervals.
- Specify the days of the week for posting.
- Set the exact time for the posts to go live.
After setting your desired schedule, click on “Save”. Your workflow is now configured to run automatically based on the schedule you set.
4. Generating Blog Content Using Google AI Studio
Next, you will connect Google AI Studio to Pabbly Connect to generate blog content. Click on “Add New Connection” and follow the prompts to authenticate your Google AI Studio account.
Once connected, specify what kind of blog content you want to generate. You can provide instructions regarding the type of content, headings, and other relevant details. This ensures that the generated content meets your requirements.
5. Posting the Generated Content to Google Blogger
Finally, you will connect your Google Blogger account with Pabbly Connect. Select your blog ID and map the title and content generated from Google AI Studio to the respective fields in Google Blogger.
After mapping the fields, click on “Save and Send Test Request”. This will create a new blog post on your Google Blogger account based on the content generated by Google AI Studio.
By following these steps, you can automate your blog posting process using Pabbly Connect and Google AI Studio. This integration allows for efficient content generation and posting, saving you time and effort.
