To start automating your Facebook posts, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect landing page. Here, you can sign in if you already have an account or sign up for free if you’re new.
Once signed in, you’ll be directed to the dashboard of Pabbly Connect. This dashboard allows you to manage all your workflows effectively. From here, you can create a new workflow to automate the process of posting on Facebook.
In this step, you will create a workflow that connects Google Sheets, OpenAI, and Facebook. Click on the “Create Workflow” option and select the “Quick Builder” method. This method simplifies the process by allowing you to enter a single line prompt.
  • Enter the prompt: “Connect Google Sheets, OpenAI, and Facebook pages.”
  • Select the trigger as “New or Updated Spreadsheet Row” for Google Sheets.
  • Choose the action from OpenAI to generate content.
  • Select the Facebook action to create a page post.
Once you’ve entered the prompt and selected the necessary actions, confirm to create the workflow. This setup will allow Pabbly Connect to automate the posting process every time you add a new row in Google Sheets.
3. Setting Up Google Sheets Integration
To connect Google Sheets with Pabbly Connect, you need to install the Pabbly Connect Webhooks add-on. Go to Extensions > Add-ons > Get Add-ons in Google Sheets, and search for “Pabbly Connect Webhooks.” Install this add-on to facilitate the connection.
After installation, refresh your Google Sheets. Navigate to Pabbly Connect Webhooks and go to the initial setup. Here, you will paste the webhook URL provided by Pabbly Connect and specify your trigger column.
  • Set your trigger column to the last column where data will be added.
  • Click on “Send Test” to send a test response to Pabbly Connect.
This configuration ensures that every time you add a new row to your Google Sheet, the data will be sent to Pabbly Connect for processing.
4. Integrating OpenAI for Content Generation
Now, it’s time to set up the integration with OpenAI. In your Pabbly Connect workflow, add a new connection for OpenAI. You will need to provide your OpenAI API key, which you can obtain from your OpenAI account.
Once connected, configure the prompt for generating content. Your prompt should include details such as the business name, audience, tone, and a call to action. This mapping of dynamic data from Google Sheets ensures the generated content is tailored to each entry.
  • Select the model, preferably GPT-5 mini, for effective content generation.
  • Map the required fields like business name and audience from the previous response.
After setting up the prompt, send a test request to verify that OpenAI generates the desired content successfully. This step is crucial for ensuring your automation works as intended.
5. Posting Generated Content on Facebook
With the content generated, the final step is to post it on Facebook. In your Pabbly Connect workflow, add a connection for Facebook Pages. Log into the Facebook account you wish to use for posting.
In the Facebook action, map the generated content and image link. Ensure that the message field includes the caption generated by OpenAI, and the image field contains the URL of the generated image.
  • Click “Save and Send Test Request” to create the post on your Facebook page.
  • Check your Facebook page to confirm that the post has been created successfully.
This integration allows you to automate the entire process, from adding a new idea in Google Sheets to posting on Facebook, all managed by Pabbly Connect.
In this tutorial, you learned how to automate Facebook posts using Pabbly Connect with Google Sheets and OpenAI. By following these steps, you can streamline your content creation and posting process effectively.
