To start using Pabbly Connect, open a new tab and navigate to the Pabbly website. If you don’t have an account, click on the “Sign Up for Free” button to create one. Once registered, you will receive 100 free tasks each month, allowing you to set up your automation without any cost.
After logging in, you will be directed to the Pabbly Connect dashboard. Here, you can create a new workflow that will connect Google Sheets and Gemini for text-to-audio conversion. This integration is essential for automating your tasks efficiently.
2. Setting Up Google Sheets with Pabbly Connect
The first step in your workflow is to set up Google Sheets as a trigger in Pabbly Connect. You will choose the “New or Updated Spreadsheet Row” trigger. This means that whenever you add new text to your Google Sheet, it will trigger the automation process.
- Go to Google Sheets and create a new sheet for your text input.
- Install the Pabbly Connect Webhook add-on from the Extensions menu.
- Configure the Webhook URL in the add-on settings to connect with your Pabbly Connect workflow.
After setting up the Webhook, you will be able to capture the text input in real-time. This step is crucial for ensuring that the data flows smoothly from Google Sheets to Pabbly Connect.
3. Configuring Gemini for Text-to-Audio Conversion
Next, you will configure the Gemini integration in Pabbly Connect. Select the “Google Air Studio Gemini Text to Speech” action. This will allow you to convert the captured text into audio format.
In this step, you will need to provide an API key from your Gemini account. To do this, navigate to the Gemini Playground section and generate your API key. Once you have the key, paste it into Pabbly Connect to establish the connection.
- Select the voice model you wish to use for the audio output.
- Map the text field from the previous step to ensure the correct text is converted.
- Choose the audio generation method and click on “Save and Test Request”.
After completing these steps, you will receive an audio URL that can be used in your Google Sheet. This integration showcases how Pabbly Connect simplifies the text-to-audio conversion process.
4. Updating Google Sheets with Audio URL
Once you have generated the audio URL, the next step is to update your Google Sheet with this link. In Pabbly Connect, select the action to update the spreadsheet cell with the audio URL.
To do this, you will need to select the specific Google Sheet and the cell where you want to insert the audio URL. This ensures that your team members can easily access the audio files directly from the sheet.
- Choose the Google Sheet where the audio URL needs to be updated.
- Specify the cell range where the audio URL will be inserted.
- Click on “Save and Send Test Request” to finalize the update.
After performing these actions, your Google Sheet will now contain the audio URL, making it accessible for any further use. This demonstrates the efficiency of using Pabbly Connect for automation.
5. Conclusion
In this tutorial, we explored how to use Pabbly Connect to automate the process of converting text to audio using Google Sheets and Gemini. By following these steps, you can streamline your workflow and enhance productivity.
Using Pabbly Connect, you can easily integrate multiple applications, ensuring that your automation processes run smoothly and efficiently. This setup allows for quick and easy access to audio files generated from text inputs, making it a valuable tool for any business.
