To begin automating customer interactions, access Pabbly Connect by visiting the Pabbly website and creating an account. This platform is essential for integrating various applications like OpenAI and Pabbly Chatbot.
Once logged in, navigate to the dashboard and click on “Create Workflow”. This will allow you to set up the automation process that connects your applications seamlessly.
2. Connecting WhatsApp with Pabbly Chatflow
In this step, you will link your WhatsApp number to Pabbly Chatflow. Start by entering the URL chatflow.pabbly.com in your browser. After logging in, you’ll need to connect your WhatsApp account.
  • Select “AI Assistant” from the left sidebar.
  • Choose the type of AI assistant you want to create.
  • Follow the prompts to link your WhatsApp account.
Completing this connection will enable your AI assistant to respond to customer inquiries automatically via WhatsApp.
3. Configuring the AI Assistant with OpenAI
Next, configure your AI assistant using Pabbly Connect and OpenAI. In the AI Assistant settings, you’ll need to set the temperature level, which controls the creativity of responses.
Choose OpenAI as your AI provider and select the model, such as GPT-5.4 or the latest GPT-6 Astra. Enter your OpenAI API key, which is crucial for the assistant to function properly.
  • Retrieve your OpenAI API key from the OpenAI API keys page.
  • Paste the API key into the designated field in Pabbly Chatflow.
  • Save your settings to ensure they are applied.
This configuration allows your AI assistant to utilize OpenAI’s capabilities to provide intelligent responses to customer queries.
4. Managing Knowledge Base for AI Responses
To enhance your AI assistant’s effectiveness, you need to upload a knowledge base. This is done through Pabbly Connect by accessing the knowledge base management section.
Upload a document (either .txt or .pdf) containing all relevant information about your business. This will serve as the foundation for the AI’s responses.
  • Ensure the document is well-structured and informative.
  • Verify that the Vector ID is correctly linked to your knowledge base.
This setup enables the AI assistant to answer customer inquiries accurately based on the provided knowledge base.
5. Finalizing and Deploying Your AI Assistant
After configuring all settings, it’s time to finalize your AI assistant in Pabbly Connect. Activate the assistant and ensure all settings are saved properly.
To deploy the assistant, you’ll need to integrate it into your website. Retrieve the embed code provided by Pabbly Chatflow and add it to your website’s HTML.
  • Copy the embed code from the Pabbly Chatflow.
  • Paste it into the HTML of your website where you want the assistant to appear.
This deployment allows your customers to interact with the AI assistant directly through your website, enhancing their experience.
In summary, using Pabbly Connect to integrate OpenAI and Pabbly Chatbot enables businesses to automate customer interactions efficiently. This setup streamlines communication and improves customer service through AI-driven responses.
