1. Accessing Pabbly Connect for Google Ads Integration
To start automating your Google Ads responses, you need to access Pabbly Connect. Open a new tab and navigate to pabbl.com/connect. If you are a new user, click on the “Sign Up Free” option to explore the platform with 100 free tasks each month.
If you are an existing user, simply click on the “Sign In” button. After logging in, you can access all Pabbly applications by clicking on the “Access Now” button for Pabbly Connect, which will take you to the dashboard.
Once you are on the Pabbly Connect dashboard, click on the “+ Create Workflow” button. You will see two options: “Create from Scratch” and “Create Using AI.” For this tutorial, select “Create Using AI” to leverage the fastest method for setting up your integration.
- Select “Create Using AI” for a quicker setup.
- Provide a prompt to the AI, such as “Create an integration between Google Ads and Pabbly Chatflow.”
After entering your prompt, the AI will ask you to select the Google Ads trigger. Choose “New Lead Form Entry” to initiate the workflow whenever a new lead is generated through your Google Ads campaign.
3. Connecting Google Ads with Pabbly Connect
After setting up your trigger, you will need to connect your Google Ads account to Pabbly Connect. You will see a webhook URL provided by Pabbly Connect. Copy this URL as you will need it for your Google Ads campaign.
Now, navigate to your Google Ads account and find the campaign where you want to add the integration. Go to the “Lead Delivery” section and paste the webhook URL into the “Webhook URL” field. Once pasted, click the “Send Test” button to verify the connection.
4. Setting Up WhatsApp Integration with Pabbly Connect
Next, you will set up the action application. For this, select Pabbly Chatflow to send WhatsApp messages to your leads. Click on the “Connect” button and add a new connection. You will be prompted to enter a token, which you can find in your Pabbly Chatflow dashboard under the API settings.
- Navigate to Pabbly Chatflow dashboard and click on “Settings.”
- Copy your API token from the API and Dabs section.
Paste this token back in Pabbly Connect and click “Save” to establish the connection. Now, you can map the WhatsApp mobile number and message fields to dynamically send personalized messages to your leads.
5. Finalizing Your Pabbly Connect Workflow
After mapping your fields, ensure that you enter the actual WhatsApp number for testing. The number should include the country code without the plus sign. Click on the “Save and Send Test Request” button to finalize your setup.
Once the request is sent, you will receive a success message indicating that the WhatsApp message has been sent. Check your WhatsApp account to confirm that the message has been received, showing that your integration is working perfectly.
Lastly, make sure to enable the toggle for your workflow. If the toggle is not enabled, your automation will not function properly. With these steps, you have successfully integrated Google Ads with WhatsApp using Pabbly Connect.
In this guide, we demonstrated how to automate responses from Google Ads to WhatsApp using Pabbly Connect. This setup ensures instant communication with leads, improving response times and enhancing customer engagement.
