To automate the creation of Pinterest pins from WordPress posts, you first need to access Pabbly Connect. Start by opening a new tab and entering the URL pabbly.com/connect.
On the homepage, you will see options to sign in or sign up for free. If you’re new, click on sign up free to create an account. Existing users can simply sign in. By signing up, you get 100 free tasks every month to explore Pabbly Connect.
Once logged into Pabbly Connect, navigate to the workflow page. Here, you will set up the automation by selecting a trigger application. In this case, select WordPress as the trigger application.
- Choose WordPress as your trigger app.
- Select the event as New Post Published.
- Click on the Connect button to generate a webhook URL.
Copy the provided webhook URL. This URL will act as a bridge between WordPress and Pabbly Connect. You will need to paste this URL into your WordPress settings.
3. Setting Up WordPress to Connect with Pabbly Connect
To connect WordPress with Pabbly Connect, install the WP Webhooks plugin. Go to the plugins section in your WordPress dashboard and search for WP Webhooks.
- Install and activate the WP Webhooks plugin.
- Navigate to the settings and choose Send Data.
- Select Post Created as the webhook trigger.
Paste the webhook URL you copied from Pabbly Connect into the designated field and save your settings. This will ensure that every time a new post is published, it triggers the webhook to Pabbly Connect.
Now that your WordPress site is connected, create a new post to test the integration. Add a title and a featured image, then publish the post.
Upon publishing, go back to Pabbly Connect to check if the webhook received the data. You should see a response indicating that the post details, including the image URL and title, were successfully captured.
This confirms that the trigger app, WordPress, is successfully integrated with Pabbly Connect. Now, you can proceed to set up the action app.
5. Creating a Pinterest Pin Using Pabbly Connect
In this step, select Pinterest as your action app in Pabbly Connect. Choose the event as Create Pin and click the Connect button.
Authorize Pabbly Connect to access your Pinterest account. After connecting, map the fields for the pin creation, such as selecting the board and entering the image URL. Use the mapping feature to dynamically pull the image URL and title from the previous step.
Finally, click Save and Send Request. You should receive a confirmation that the pin was created successfully in your Pinterest account. This completes the automation process, allowing you to generate Pinterest pins automatically from your WordPress posts using Pabbly Connect.
By utilizing Pabbly Connect, you can automate the process of creating Pinterest pins from your WordPress posts. This integration saves time and enhances your online presence without manual effort. Start using Pabbly Connect today to streamline your automation tasks!
