To start using Pabbly Connect for WhatsApp broadcasts, first, visit the Pabbly Chatflow website. This platform allows you to manage your WhatsApp communications efficiently. If you are a new user, click on the “Sign up for free” option to create an account, or if you’re an existing user, simply sign in.
After signing in, you will be directed to the Pabbly apps window. Here, locate and click on “Access Now” under Pabbly Chatflow. This is where you can set up your WhatsApp integration. Ensure you have connected your WhatsApp number to your Pabbly Chatflow account for the next steps.
2. Creating a WhatsApp Template in Pabbly Chatflow
In order to send bulk messages, you need to create a WhatsApp template using Pabbly Connect. Navigate to the template section within your Pabbly Chatflow dashboard. Here, you can view your existing templates and create a new one by clicking on the “Add Template” button.
  • Choose a name for your template that reflects its purpose.
  • Add any media files you want to include in your message.
  • Submit the template for approval by Meta.
Once your template is approved, you can use it to send personalized messages to your customers. Make sure to note the template name for the next steps in your WhatsApp broadcast process.
3. Setting Up the WhatsApp Broadcast with Pabbly Connect
To set up your WhatsApp broadcast, go to the broadcast section in Pabbly Connect. Click on the “Add Broadcast” button to create a new broadcast campaign. Here, you’ll need to name your campaign and select the contact list you want to send messages to.
Since you will be using contacts from a Google Sheet, ensure that you have uploaded these contacts into your Pabbly Chatflow account. You can do this by importing a CSV file. Once your contacts are ready, select them from the contact list.
4. Sending Bulk WhatsApp Messages Using Pabbly Connect
With your broadcast set up, it’s time to send your messages. Choose the message type as either a pre-approved template or a regular message. If you’re using a pre-approved template, select it from the dropdown menu. You can also customize the message body to include variables, making it dynamic for each recipient.
  • Test your broadcast by sending a message to your own WhatsApp number first.
  • Schedule the broadcast for a specific date and time if needed.
  • Check the statistics after sending to see how many messages were delivered, read, or failed.
After testing, you can proceed to send your broadcast to the selected contacts. This feature of Pabbly Connect makes it easy to manage bulk messaging effectively.
5. Conclusion: Streamlining Communication with Pabbly Connect
Using Pabbly Connect to send bulk WhatsApp messages is a game changer for businesses. With the ability to create personalized templates and manage contacts seamlessly, you can enhance your customer engagement significantly. This tutorial has walked you through every step of the process, ensuring you can implement this powerful solution effectively.
Now that you know how to utilize Pabbly Connect for WhatsApp broadcasts, you can improve your communication strategy and save time. Start sending personalized messages today!
