1. Setting Up Pabbly Connect for WhatsApp Broadcast
To start using Pabbly Connect, log in to your account and navigate to the Pabbly Chat Flow feature. This platform allows you to create WhatsApp broadcasts effortlessly. You’ll be able to send promotional messages to your clients without any manual effort.
Once you’re in Pabbly Chat Flow, locate the Broadcast feature. This is crucial for setting up your WhatsApp broadcast campaign. You can create a new broadcast by clicking on the “Add Broadcast” button, which will guide you through the process of selecting your audience.
2. Selecting Your Audience for the Broadcast
In this section, you will choose the audience for your broadcast campaign using Pabbly Connect. You have two options: select an existing contact list or upload a CSV file. Choosing the right audience is vital for targeting your promotional messages effectively.
  • Select an existing contact list from your database.
  • Upload a CSV file containing your contacts.
  • Ensure your CSV file includes first name, last name, and phone number.
After selecting your audience, you can refine it further. This optional step allows you to exclude any contacts you don’t want to receive the broadcast. You can also skip contacts who have messaged you in the last 24 hours to avoid redundancy.
3. Creating Your Message Template
Next, you will create the message template for your WhatsApp broadcast using Pabbly Connect. You can choose between a pre-approved template or a regular message. If you want to initiate a conversation, a pre-approved template is necessary.
To create your message, select the template option and choose from your previously created templates. For this example, let’s use a skincare marketing message template. You can also add images to make your message more engaging.
  • Select a template from your library.
  • Add images to enhance your message.
  • Preview the message to ensure it looks good.
After finalizing your template, you can test the message by sending a test broadcast to your contact. This is a great way to confirm that everything appears correctly before the actual send-out.
4. Scheduling Your Broadcast Campaign
Once your message is ready, you can schedule the broadcast using Pabbly Connect. You have the option to send the message immediately or schedule it for a later date. Scheduling allows you to plan your campaigns effectively.
To schedule your broadcast, select the date and time you want the message to go out. For example, you might choose to send it on October 28 at 5:00 PM. This feature ensures that your messages reach your audience at the right moment.
Additionally, you can enable automatic retries for any contacts that fail to receive the message. This ensures that your promotional messages are delivered without manual intervention, enhancing the effectiveness of your campaign.
5. Monitoring Broadcast Results with Pabbly Connect
Finally, after your campaign is sent, you can monitor its performance using Pabbly Connect. This feature allows you to view statistics and see how well your broadcasts are performing. You can analyze delivery rates and engagement metrics to improve future campaigns.
To view the statistics, click on the “View Statistics” button. You can also export reports for further analysis. This step is essential for understanding your audience’s response and optimizing your messaging strategy.
Using Pabbly Connect not only simplifies the process of sending WhatsApp broadcasts but also provides you with the tools to refine your approach based on data-driven insights.
In this tutorial, we explored how to use Pabbly Connect to create a WhatsApp broadcast campaign with Pabbly Chat Flow. By following these steps, you can effectively engage your audience and improve your marketing efforts.
