To begin using Pabbly Connect, first navigate to the Pabbly website. If you’re new, you can sign up for a free trial. This allows you to integrate up to 100 Facebook leads into your PipeDrive account seamlessly.
Once signed in, you will be directed to the workflow builder. This is where all automation takes place, leveraging the power of Pabbly Connect to facilitate connections between applications.
2. Creating a Trigger in Pabbly Connect
The first step in our integration process is to create a trigger. Click on the “Add Trigger” button and search for “Facebook Lead Ads” to select it. For the event, choose “New Lead Instant” and click on connect.
Ensure your Facebook account is logged in. If you have an existing connection, you can select it; otherwise, click on “Add a New Connection” to link your Facebook lead ads account. After logging in, click on “Continue” to proceed.
- Select the Facebook page associated with your leads.
- Choose the specific lead form you wish to automate.
- Set the response format to simple and click on “Save and Send Test Request”.
After completing these steps, Pabbly Connect will be ready to capture lead responses from Facebook, enabling you to automate the process effectively.
3. Capturing Lead Information from Facebook
Once the trigger is set, you need to capture lead information. Open the Lead Ads Testing Tool via Meta for Developers. Select the same page and form you used earlier.
Fill in the lead form with test data, such as a name and email, and submit it. This submission will allow Pabbly Connect to capture the response, confirming that the connection is successful.
After submitting the test lead, return to your workflow in Pabbly Connect. You should see the captured data reflecting the lead details. This indicates that your Facebook lead ads are now connected correctly.
4. Setting Up Action in Pabbly Connect
Next, add an action step by clicking “Add New Action Step”. Search for “PipeDrive” and select it. For the event, choose “Create a Person” and click on connect.
If you have an existing connection with PipeDrive, select it. Otherwise, create a new connection by entering your API token from your PipeDrive account. Navigate to your user settings, find the API section, and copy the token.
- Map the lead details from Facebook to PipeDrive.
- Enter first name, last name, email, and phone number as required.
- Click on “Save and Send Test Request” to finalize the action.
Upon successful mapping, Pabbly Connect will confirm that a new contact has been created in your PipeDrive account, completing the integration process.
5. Verifying Integration Success
To ensure the integration works, check your PipeDrive account. Navigate to the contacts section to see if the new lead is listed. This confirms that the automation is functioning correctly.
Every time a new lead fills out your Facebook form, Pabbly Connect will automatically add them to your PipeDrive account as a new contact. This automation saves time and enhances efficiency in managing leads.
Feel free to experiment with different forms or settings within Pabbly Connect to optimize your lead management process further. The possibilities are vast, and you can connect multiple applications for enhanced productivity.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the integration of Facebook leads into PipeDrive. By following these steps, you can streamline your lead management process effectively.
Automating this workflow not only saves time but also ensures that no lead goes unnoticed. Start using Pabbly Connect today to enhance your business operations!
