To start your integration between Facebook Lead Ads and GoHighLevel, you need to access Pabbly Connect. Open a new tab and type pabbly.com/connect in your browser. This will take you to the Pabbly Connect landing page, where you can sign up for a free trial.
Click on the ‘Sign Up for Free’ option in the top right corner. After activating your free trial, you will be directed to the Pabbly Connect dashboard. Here, click on ‘Create Workflow’ and choose the quick builder option to set up your integration.
2. Create Workflow in Pabbly Connect
Once you are in the Pabbly Connect dashboard, you need to create a new workflow. Type “Facebook Leads to GoHighLevel” in the workflow name field. After this, click on the send button to proceed.
Pabbly Connect will analyze your request. When prompted, select “Facebook Lead Ads” as the application you want to integrate. The event to choose here is “New Lead Instant”. For GoHighLevel, search for “Lead Connector V2” and select it. Make sure to choose the event as “Create or Update a Contact” and click on ‘Approve and Create’.
3. Connect Facebook Lead Ads with Pabbly Connect
Next, you will connect your Facebook Lead Ads account to Pabbly Connect. Ensure that you are logged into your Facebook account. Click on the connect button for Facebook Lead Ads and then select ‘Add a New Connection’. Choose the Facebook account you wish to use and click on the ‘Continue’ button.
- Make sure your Facebook account is logged in before starting.
- Select the appropriate page name and form for your automation.
- Choose to create automation for all lead gen forms if needed.
After establishing the connection, set the response format to simple and click on the ‘Save and Send Test Request’ button. Pabbly Connect will now wait for a webhook response.
4. Capture Webhook Response Using Meta for Developers
To capture the webhook response, open another tab and search for “Meta for Developers”. Navigate to the developer tools and find the “Lead Ads RTU Debug Tool”. Select the same page and form you used in Pabbly Connect and choose “Lead Retrieval” as the product.
Click on the “Preview Form” button to generate a test lead. Fill in the form with test details and submit it. Once submitted, return to Pabbly Connect, where it will capture the response from the test lead.
After capturing the response, you can check your GoHighLevel account to see your existing contacts. You should see the total number of contacts displayed in your dashboard.
5. Create Contact in GoHighLevel Using Pabbly Connect
Now, you will create a new contact in GoHighLevel. Click on the connect button again and select “Lead Connector V2” for GoHighLevel. Ensure that you are logged into your GoHighLevel account before proceeding.
Pabbly Connect will request permissions; grant all required permissions. It’s important to select the appropriate sub-account rather than the agency account. After connecting, you will be prompted to enter the details for the new contact.
- Map the lead details from the previous step into the fields provided.
- Use the mapping feature in Pabbly Connect to dynamically insert data.
- Fill in only the details you have from the lead.
Once all details are mapped correctly, click on the ‘Save and Send Test Request’ button. If successful, you will see a confirmation that a new contact has been created in your GoHighLevel account.
In this tutorial, we demonstrated how to integrate Facebook Lead Ads with GoHighLevel using Pabbly Connect. By following these steps, you can automate the process of adding new leads directly into your GoHighLevel account, enhancing your marketing efforts efficiently.
