To begin integrating WhatsApp with Facebook Lead Ads, first access Pabbly Connect by visiting pabbl.com/connect. This powerful platform allows you to automate and connect multiple applications without coding.
If you are new to Pabbly Connect, click on “Sign Up Free” to create an account. Existing users can sign in directly. After signing in, navigate to the Pabbly Connect dashboard to start creating your workflow.
Once on the dashboard, click the “Create Workflow” button. Select the “Create from Scratch” option to build your workflow. Name your workflow something like “Facebook Lead Ads + WhatsApp = Instant Lead Follow-Up System”.
- Click on the “Create” button to finalize your workflow setup.
- Select the trigger application as “Facebook Lead Ads”.
- Choose the event as “New Lead Instant”.
After selecting your trigger, click the “Connect” button to establish a connection with Facebook Lead Ads. You will need to add a new connection if you don’t have an existing one.
3. Configuring Facebook Lead Ads in Pabbly Connect
In this step, you will connect your Facebook account. Click on “Connect with Facebook Lead Ads” and authorize the connection. Once connected, select the appropriate Facebook page and lead generation form.
For response format, choose “Simple”. Then click on “Save and Send Test Request”. This action will start waiting for a webhook response from Facebook.
- Open the Meta for Developers page and navigate to the “Lead Ads Debug Tool”.
- Select your page and form, then click on “Create Lead” to generate a test lead.
Once a test lead is created, check back in Pabbly Connect to ensure the new response has been received, confirming your trigger is functioning correctly.
Next, set up the action application to send WhatsApp messages. Choose Pabbly Chatflow as your action application. Select the event “Send Text Message” and click on “Connect”.
To connect, you will need an API token from your Pabbly Chatflow account. Go to the settings in Pabbly Chatflow, locate the API section, and copy your token. Paste it into the required field in Pabbly Connect.
- Map the recipient’s mobile number from the Facebook Lead Ads response.
- Craft your WhatsApp message by including dynamic fields such as the user’s name.
Finally, click on “Save and Send Test Request” to send a test message through WhatsApp. Ensure the message is received successfully to confirm the action step is working.
5. Finalizing Your Pabbly Connect Workflow
After confirming that WhatsApp messages are being sent correctly, toggle the workflow to enable it. This step is crucial; if the toggle is off, the automation will not function.
With this setup, every time a new lead comes through your Facebook Lead Ads, Pabbly Connect will automatically send a personalized WhatsApp message to the user. This automation significantly speeds up lead response times and boosts conversion rates.
In summary, by utilizing Pabbly Connect, you can easily integrate WhatsApp with Facebook Lead Ads, ensuring timely communication with your leads. This system can be adapted for various business needs, enhancing your customer engagement.
In this tutorial, we demonstrated how to integrate WhatsApp with Facebook Lead Ads using Pabbly Connect. This automation allows for instant lead follow-up, enhancing response times and improving conversions. Implementing this system can greatly benefit your business operations.
