1. Setting Up Pabbly Connect for Event Confirmation
To automate event confirmations, start by accessing Pabbly Connect. This powerful tool allows you to integrate various applications seamlessly, including Zoho Forms and WhatsApp.
After signing up at the Pabbly Connect website, you will be greeted with a dashboard. Click on the ‘Create Workflow’ button to initiate your automation process. This setup is crucial for ensuring that event registrations trigger an immediate WhatsApp confirmation message.
2. Creating the Trigger with Zoho Forms
In this step, you will set up the trigger for your workflow using Zoho Forms within Pabbly Connect. Select Zoho Forms as your trigger application and choose the event “New Form Submitted”.
- Select “New Form Submitted” as the app event.
- Click on the “Connect” button to generate a webhook URL.
- Copy the webhook URL for the next step.
Now, navigate to your Zoho Forms account. Here, you will paste the copied webhook URL into the integration settings of your event registration form. This connection allows Pabbly Connect to receive data from Zoho Forms whenever a new registration is submitted.
3. Mapping Data from Zoho Forms to Pabbly Connect
Once the webhook is set up, it’s time to test the connection. Fill out your Zoho form with test data, including the user’s name and ticket type. After submitting the form, Pabbly Connect will capture this data.
In your Pabbly Connect workflow, you should see the response from Zoho Forms. This response contains all the details entered by the user. Ensure that the data is correctly mapped to be used in the next steps of your automation.
- Verify that all fields are receiving the correct data.
- Make adjustments if necessary to ensure accurate data capture.
This step is crucial as it ensures that the personalized WhatsApp messages will contain the correct information for each user.
4. Sending Personalized WhatsApp Messages Using Pabbly Chatflow
Next, you will set up the action step to send a WhatsApp message using Pabbly Chatflow, which works seamlessly with Pabbly Connect. Select Pabbly Chatflow as your action application and choose the event “Send Text Message”.
To establish this connection, you will need to provide your API token from your Pabbly Chatflow account. This token ensures that your WhatsApp messages are sent securely and effectively.
- Access your Pabbly Chatflow account and navigate to the API settings.
- Copy the API token and paste it into Pabbly Connect.
- Map the recipient’s WhatsApp number using the data from Zoho Forms.
This mapping allows each user to receive their unique confirmation message, making the process personalized and efficient.
5. Testing the Integration and Finalizing the Workflow
After setting up your WhatsApp messaging action, it’s time to test the entire workflow. Click on the “Save and Send Test Request” button in Pabbly Connect to simulate a real user interaction.
Once the test is complete, check your WhatsApp account to confirm that the message has been received. The message should include personalized details such as the user’s name and ticket type, demonstrating that the integration works flawlessly.
Finally, make sure to enable the workflow toggle in Pabbly Connect to ensure that it runs automatically for future registrations. This step is essential for maintaining the automation without manual intervention.
In summary, using Pabbly Connect, you can efficiently automate event confirmations through WhatsApp and Zoho Forms. This integration saves time and enhances user experience by delivering instant notifications.
