1. Accessing Pabbly Connect for AI Integration
To engage website visitors effectively, you first need to access Pabbly Connect. This platform serves as the core integration tool that connects various applications, including OpenAI and WhatsApp.
Open your browser and navigate to the Pabbly Connect website. If you are new, sign up for a free account to explore its features. Existing users can log in directly. Pabbly Connect provides a user-friendly interface for setting up integrations seamlessly.
2. Creating Your AI Assistant with Pabbly Chatbot
Once you have accessed Pabbly Connect, the next step is to create your AI assistant using Pabbly Chatbot. This tool allows you to design an AI assistant without needing coding skills.
  • Navigate to the AI assistant page within Pabbly Chatbot.
  • Select the instruction type as “AI agent”.
  • Choose OpenAI as the AI model for your assistant.
After configuring these options, you can set the temperature for responses, which controls the creativity of the AI’s answers. A lower value means more focused responses, while a higher value allows for more creative outputs.
3. Connecting OpenAI API to Pabbly Connect
Integrating OpenAI with Pabbly Connect is crucial for your AI assistant to function effectively. You will need your OpenAI API key to establish this connection.
In the configuration settings, locate the API key field and paste your OpenAI key. Click the connect button to save your settings. This step ensures that your AI assistant can generate responses based on the knowledge base you have provided.
  • Enter your OpenAI API key in the designated field.
  • Adjust other settings like stop keywords and retry attempts as needed.
Once connected, your assistant will be able to utilize the OpenAI model to respond to visitor queries based on the knowledge base you have set up.
4. Uploading Your Knowledge Base for AI Responses
The next step in using Pabbly Connect is to upload a knowledge base that will inform your AI assistant’s responses. This is essential for answering visitor queries accurately.
Navigate to the knowledge base section and upload your document containing details about your business, such as services offered by Heaven Stone Realty. This document will help the AI assistant respond to questions like “What type of properties does Heaven Stone Realty offer?”
  • Select the knowledge base file from your media library.
  • Insert it into the designated area in Pabbly Connect.
By doing this, you ensure that the AI assistant can provide relevant answers to user queries effectively.
5. Embedding Your AI Assistant on the Website
After setting up your AI assistant in Pabbly Chatbot, the final step is to embed it on your website. This allows visitors to interact with the assistant directly.
To do this, click on the embed button in Pabbly Connect to receive the JavaScript code snippet. Copy this code and paste it into the JavaScript section of your website’s code.
  • Access your website’s code editor.
  • Paste the copied JavaScript code in the appropriate section.
Once saved, refresh your website, and you will see the WhatsApp icon appear. Users can now click this icon to start a chat with your AI assistant, enhancing engagement and support for Heaven Stone Realty.
In this tutorial, we explored how to engage website visitors using Pabbly Connect and an AI assistant. By following these steps, you can enhance customer interactions and provide immediate support through WhatsApp, improving the overall user experience.
