To begin with Pabbly Connect, access your Pabbly account and navigate to the Pabbly Connect dashboard. Here, you will create a workflow that connects Google Sheets with Gmail for sending personalized emails.
Click on the “Create Workflow” button. Choose “Create from Scratch” and name your workflow, for instance, “Send Emails in One Click”. Select the folder where you want to save this workflow and click on “Create”. This action opens the Pabbly Connect workflow automation window.
2. Setting Up Trigger with Google Sheets in Pabbly Connect
The first step in your automation process involves setting up a trigger in Pabbly Connect. Select “Google Sheets” as your trigger application. The event you will choose is “New or Updated Spreadsheet Row” to start the automation whenever there is new data.
  • Select “Google Sheets” as the trigger application.
  • Choose the event “New or Updated Spreadsheet Row”.
  • Click on the “Connect” button to establish a connection.
After clicking “Connect”, a Webhook URL will be generated. Copy this URL, then go to your Google Sheets. In the Google Sheets, navigate to “Extensions”, then “Add-ons”, and search for Pabbly Connect. Install it if you haven’t done so already. Refresh your spreadsheet to see the Pabbly Connect option.
3. Initial Setup in Google Sheets for Pabbly Connect
After installing the Pabbly Connect add-on in Google Sheets, click on it and select “Initial Setup”. A dialog box will appear where you will paste the Webhook URL you copied earlier. Specify the trigger column, which is the final data column that will initiate the webhook.
  • Paste the copied Webhook URL in the dialog box.
  • Set the trigger column to the column where final data is entered.
  • Click “Send Test” to verify the setup.
Once you click “Send Test”, the data from your Google Sheets will be sent to Pabbly Connect. Verify that the test data is received correctly in your Pabbly Connect workflow. If successful, click on “Submit” to finalize the connection setup.
4. Configuring Gmail Action in Pabbly Connect
Next, you need to set up the action step in Pabbly Connect. Click on “Add Action Step” and select “Gmail” as the action application. Choose the action event as “Send Email” and click on “Connect”.
If you already have a connection, you can save it. Otherwise, click on “Add New Connection” and sign in to your Google account. Grant the necessary permissions to allow Pabbly Connect to send emails through your Gmail account. Once connected, you will need to configure the email details.
5. Personalizing Email Content in Pabbly Connect
In the email configuration, fill in the sender’s name and email address, which will be pre-filled based on your connection. For the recipient’s email address, map it from the Google Sheets data you received earlier. This mapping ensures that the emails are personalized for each recipient.
  • Enter the sender’s name and email address.
  • Map the recipient’s email address from the Google Sheets data.
  • Compose the email subject and body using mapped variables for personalization.
Once you have set up the email content, click on “Save and Send Request”. You should receive a positive response indicating that the email has been sent successfully. Check your Gmail inbox to confirm that the personalized email was received as intended.
Using Pabbly Connect allows for seamless integration between Google Sheets and Gmail, facilitating the automation of personalized emails. This process enhances efficiency in communication and ensures a tailored approach to reaching out to contacts.
