To start integrating WhatsApp with Pabbly Chatflow, first, you need to access the platform. Visit the Pabbly website and navigate to the Chatflow section. If you are a new user, sign up to create your account and receive 100 free credits monthly.
Once you log into Pabbly Chatflow, you will land on the dashboard. This is where you can manage your WhatsApp messages and broadcasts effectively. Familiarize yourself with the layout to ensure a smooth setup process.
2. Adding Your WhatsApp Number to Pabbly Chatflow
The next step is to add your WhatsApp number to Pabbly Chatflow. This is crucial for sending messages to your contacts. Navigate to the settings and look for the option to add your WhatsApp number.
  • Go to the settings section.
  • Select the option to add a WhatsApp number.
  • Follow the prompts to verify your number.
After your number is added, you can start utilizing the broadcast feature. This setup is essential for sending individual messages through WhatsApp using Pabbly Chatflow.
3. Uploading Contacts for Broadcasts in Pabbly Chatflow
Before sending messages, you need to upload your contacts into Pabbly Chatflow. You can do this by navigating to the contacts feature and selecting the option to add contacts. It is recommended to upload contacts in bulk using a CSV file.
  • Prepare your contacts in a CSV file using Excel or Google Sheets.
  • Ensure the file is under 50 MB and contains no more than 200,000 contacts.
  • Upload the CSV file in the contacts section of Pabbly Chatflow.
Once your contacts are uploaded, you can create a list and prepare for broadcasting messages through WhatsApp.
4. Creating and Scheduling Broadcasts in Pabbly Chatflow
After uploading your contacts, navigate to the broadcast feature in Pabbly Chatflow. Click on the “add broadcast” button to initiate the process. You will be prompted to select a broadcast type and name your broadcast.
Ensure you select the correct contact list and refine your audience if necessary. This helps in targeting specific users while avoiding unnecessary messages. You can also choose between sending a pre-approved message or a regular message.
Once your broadcast is set up, you can schedule it for later or send it instantly. This flexibility allows you to plan your communications effectively. After scheduling, your broadcast will be ready to go out at the specified time.
5. Testing Your Broadcasts in Pabbly Chatflow
Before finalizing your broadcast, it is essential to test it. In Pabbly Chatflow, you can send a test message to ensure everything is functioning correctly. Enter a test number and click on the “send test message” button.
Once you receive the test message, check if it includes all the necessary details. This step is crucial to confirm that your broadcast setup is working perfectly. After testing, you can proceed to finalize your broadcast and monitor its performance through the stats feature.
Pabbly Chatflow makes it easy to manage and analyze your broadcasts, ensuring effective communication with your audience.
Integrating WhatsApp with Pabbly Chatflow allows businesses to automate their communication effectively. By following this guide, you can set up broadcasts, manage contacts, and enhance engagement with your audience seamlessly.
