To create a WhatsApp chatbot, first, access Pabbly Connect by visiting chatflow.pabbly.com. This platform will enable you to integrate various applications seamlessly.
Once on the site, you can create an account or log in. Ensure you add your WhatsApp number to your Pabbly Connect account for the integration to work effectively.
2. Building Your WhatsApp Chatbot with Pabbly Chat Flow
After logging into Pabbly Connect, navigate to the “Flows” section. This is where you will build your WhatsApp chatbot using the automation tools provided.
Drag and drop the elements to create a workflow. The main components you will use include:
  • Triggers: Events that start your chatbot
  • Actions: Responses your chatbot will provide
  • Variables: Store user input
You can easily connect these elements to create a functional chatbot flow.
3. Setting Up Triggers in Pabbly Connect
Triggers in Pabbly Connect are essential as they initiate the chatbot’s actions. For example, you can set a trigger for when a user types “Hello”. This will start the interaction.
To set this up, choose the trigger option and input your keyword. You will also have options to customize responses, ensuring users receive immediate feedback when they engage with your chatbot.
4. Creating Responses and Actions for Your Chatbot
After setting up triggers, the next step in Pabbly Connect is to create responses. You can add various responses based on the user’s input. For instance, if a user selects a service, you can provide a list of options.
To do this, use the “Action” block to define the messages your bot will send. You can also create buttons for users to click, which makes the interaction more engaging. This can be done by dragging the button element into your flow and customizing its text.
5. Finalizing and Saving Your WhatsApp Chatbot
Once you have set up your triggers and responses in Pabbly Connect, it’s crucial to save your work. Click on the save button to ensure your chatbot is ready for deployment.
With everything set, you can test your chatbot to verify that it works as intended. Make sure to check all possible user interactions to ensure a smooth user experience.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Connect and its features. By following the steps outlined, you can automate interactions with your customers effectively.
