1. Accessing Pabbly Chatflow for Your WhatsApp Chatbot
To design a multi-step WhatsApp chatbot, you need to access Pabbly Chatflow. Start by navigating to the Pabbly Chatflow homepage. If you are a new user, click on “Sign Up Free”; if you already have an account, simply click on “Sign In”. This step is crucial as Pabbly Chatflow is the central platform for creating your chatbot.
Once logged in, you will be directed to the flow page where you can create and manage your chatbots. Here, you can add your WhatsApp number to your Pabbly Chatflow account, which is essential for the integration to work effectively.
2. Creating the Chatbot Flow in Pabbly Chatflow
Now that you have accessed Pabbly Chatflow, it’s time to create the flow for your WhatsApp chatbot. This involves selecting the trigger event, which will initiate the chatbot. For this example, the keyword “hello” will serve as the trigger. When a user sends this message, the chatbot will respond with a welcome message.
  • Select the “Text Button” node from the actions block.
  • Drag and drop it into your flow.
  • Create two buttons: “Our Services” and “Ask Questions”.
After setting up the buttons, you can link them to the respective responses. For instance, if a user clicks on “Our Services”, they will receive a list of available services. This is where Pabbly Chatflow shines, allowing for an interactive user experience.
3. Integrating Google Sheets with Pabbly Connect
To save user data, you need to integrate Google Sheets using Pabbly Connect. This integration allows you to capture information like business names and email addresses entered by users. Start by adding an API Request node in your flow to establish a connection with Pabbly Connect.
In the API Request node, you will need to enter the webhook URL provided by Pabbly Connect. This URL is essential for sending data to your Google Sheets. After setting this up, you can define the parameters for the data being sent, such as the user’s business name, full name, and email address.
  • Enter the webhook URL in the API Request node.
  • Define the parameters for data storage.
  • Send test data to verify the connection.
Once the data is successfully sent to Google Sheets, you can check your sheet to confirm that all information is saved correctly. This integration is a key feature of Pabbly Connect and enhances the functionality of your chatbot.
4. Handling User Queries with AI in Pabbly Chatflow
Another impressive feature of Pabbly Chatflow is its ability to handle user queries using AI. When a user selects the “Ask Questions” button, the chatbot can provide answers based on pre-defined AI responses. This automation saves time and enhances user experience.
To set this up, you will need to assign an AI assistant to the question node in your flow. This assistant will respond to user inquiries based on the information available in your chatbot. Users can ask questions like “Do you create content?” and receive instant responses, making the interaction seamless.
  • Select the AI Assistant option from the sidebar.
  • Set the welcome message for the AI assistant.
  • Test the AI responses by asking various questions.
This feature demonstrates how Pabbly Chatflow can enhance customer service by providing quick answers to common queries, thus automating the communication process effectively.
5. Finalizing Your WhatsApp Chatbot with Pabbly Chatflow
After setting up all the components, it’s time to finalize your WhatsApp chatbot. Ensure that all nodes are connected correctly and that the flow is logical. This step is essential for a smooth user experience when interacting with your chatbot.
Once you are satisfied with your setup, you can publish your chatbot. Users can now initiate conversations by sending the keyword “hello” on WhatsApp, and your chatbot will guide them through the multi-step process. This is where Pabbly Chatflow truly excels in creating automated workflows.
By utilizing the features of Pabbly Chatflow, you can automate various tasks, from saving data to answering queries. This makes it a valuable tool for any business looking to enhance customer interaction.
In this tutorial, we explored how to design a multi-step WhatsApp chatbot using Pabbly Chatflow. By integrating it with Google Sheets through Pabbly Connect, you can automate customer interactions effectively. Start using Pabbly Chatflow today to enhance your business operations!
