To start using Pabbly Connect, first, visit the Pabbly website. You can sign up for a free account or log in if you are an existing user. Once logged in, you will have access to all the features necessary for integration.
After accessing your dashboard, locate the Pabbly Connect option. This platform will allow you to connect your applications, specifically Pabbly, Pabbly Chat Flow, and Pabbly Hindi. You can initiate the integration by clicking on the “Create Workflow” button.
2. Connecting Pabbly Chat Flow with Pabbly Connect
To connect Pabbly Chat Flow using Pabbly Connect, navigate to the Chat Flow section. You need to create a new chatbot for your dental clinic. Click on “Add AI Assistant” to begin the setup process.
- Select a name for your AI Assistant.
- Fill in the required details in the setup form.
- Configure the AI settings according to your business needs.
After filling in the details, proceed to configure the AI’s behavior. This includes setting the temperature for responses, which determines how creative the answers will be. You can set this to zero for focused responses or one for creative interactions.
3. Configuring the AI Assistant in Pabbly Chat Flow
Within Pabbly Connect, you can customize your AI Assistant to respond to user queries effectively. Start by selecting the AI instruction type that suits your service. This configuration is crucial for ensuring that your chatbot provides accurate information.
Next, you will need to enter the OpenAI API key to enable the AI functionalities. If you don’t have an API key, you can generate one by visiting the OpenAI website and creating a new secret key.
- Ensure you have a paid OpenAI account for full functionality.
- Set the header and footer messages for your chatbot.
- Define stop keywords to manage user interactions effectively.
Once you have configured these settings, save your AI Assistant. This will ensure that your chatbot is ready to handle conversations related to your dental services.
4. Testing Your Chatbot with WhatsApp Integration
After setting up your AI Assistant through Pabbly Connect, it’s time to test its functionality. Open WhatsApp and send a query to see how your chatbot responds. For example, you can ask, “Do you provide dental implants?” and check if the response is accurate.
In this testing phase, you should validate that the chatbot can handle both English and Hindi queries, providing appropriate responses in the respective languages. This feature is essential for reaching a broader audience.
Ensure that your chatbot can manage various queries effectively, including appointment bookings and service inquiries. If everything works as expected, you can confidently deploy your chatbot for customer interactions.
5. Assigning the Chatbot to Your Contacts
To finalize the setup, you need to assign your AI Assistant to specific contacts or groups within WhatsApp. This is done through the settings in Pabbly Connect. Navigate to the inbox settings, where you can enable the AI auto-reply feature.
From there, select the contacts or groups you want the chatbot to interact with. This ensures that your AI Assistant is available to respond to user queries promptly. You can also create rules for different lists of contacts to streamline responses.
- Choose the contacts to assign the AI Assistant.
- Save the settings to activate the chatbot for those users.
By following these steps, your dental clinic’s chatbot will be fully operational, enhancing customer service through automated WhatsApp interactions.
In this tutorial, we explored how to integrate Pabbly, Pabbly Chat Flow, and Pabbly Hindi using Pabbly Connect. By setting up a chatbot, you can automate your dental clinic’s WhatsApp communications effectively, improving customer engagement.
