1. Accessing Pabbly Connect for Customer Onboarding
To begin automating your customer onboarding process, first, access Pabbly Connect. Visit pably.com in your browser and sign in or sign up for a free account. If you’re a new user, you can explore free tasks to understand how it fits your business needs.
Once signed in, navigate to the Pabbly Apps page and click on “Access Now” under Pabbly Connect. This will take you to the Pabbly Connect dashboard where you can create a new workflow for your customer onboarding process.
Creating a new workflow is essential for integrating Gmail and HubSpot through Pabbly Connect. Click on “Create Workflow” and name your workflow appropriately. Choose a folder if needed, then click “Create” to proceed.
- Name your workflow clearly for easy identification.
- Select a relevant folder to organize your workflows.
After creating the workflow, you will see two boxes: Trigger and Action. The Trigger is the application that starts the workflow, while Action is what happens as a result of the Trigger. In this case, the Trigger will be Razorpay, and the Action will involve both HubSpot and Gmail.
3. Setting Up the Trigger with Razorpay
To set up the Trigger, select Razorpay as your application in Pabbly Connect. Choose the event “Payment Captured” and click on “Connect”. This will allow you to capture payment details when a new payment is made.
Next, copy the Webhook URL provided by Pabbly Connect and paste it into Razorpay. Navigate to the Developers section in Razorpay, find the APIs and Webhooks option, and click on “Add New Webhook”. Paste the URL, select your active event, and click “Create Webhook” to finalize the setup.
4. Sending Personalized Email via Gmail
After setting up the Trigger, the next step is to send a personalized email using Gmail through Pabbly Connect. Select Gmail as your Action application and choose the event “Send Email”. Click on “Connect” to link your Gmail account.
- Choose the sender’s name and email address.
- Enter the recipient’s email address dynamically using the captured payment details.
- Set the email subject and content, personalizing it with customer details.
After entering all necessary details, click on “Save and Send Test Request” to check if the email sends successfully. This confirms that your integration is working properly.
5. Creating a Contact in HubSpot
The final step in your customer onboarding process is to create a contact in HubSpot using Pabbly Connect. Select HubSpot as your next Action application and choose the event “Create Contact”. Click on “Connect” to link your HubSpot account.
Map all the necessary fields from the Razorpay payment details to HubSpot contact fields. Ensure to capture the first name, last name, and email address accurately. After mapping, click on “Save and Send Test Request” to verify that the contact is created successfully in HubSpot.
By following these steps, you can effectively automate your customer onboarding process using Pabbly Connect with Gmail and HubSpot. This integration not only streamlines your workflow but also enhances customer engagement through personalized communication.
