To start integrating Now, API, GPD, and other applications, you first need to access Pabbly Connect. This platform acts as the central hub for your automation needs, allowing seamless connections between various applications.
Begin by visiting the Pabbly Connect website. If you are a new user, you can sign up for a free trial to explore its features. Existing users can simply log in to access their dashboard. Once logged in, you can create a new integration workflow.
2. Setting Up Your Integration Workflow
In this section, you will learn how to set up your integration workflow using Pabbly Connect. Click on the “Create Workflow” button to start. You will be prompted to name your workflow, which helps in identifying it later.
- Select the trigger application (e.g., Now, API).
- Configure the trigger settings based on your requirements.
- Test the trigger to ensure it captures the right data.
After setting up the trigger, you can proceed to define the actions that will take place once the trigger is activated. This is where Pabbly Connect excels, enabling you to automate tasks across various applications seamlessly.
3. Configuring Your AI Assistant
Next, configure your AI assistant within Pabbly Connect. This involves selecting the AI model you want to use, such as GPD or GPT. You will need to input your API key, which can be obtained from the respective AI service provider.
Ensure that you set the temperature for your AI responses. A lower temperature (0.0) provides more focused answers, while a higher temperature (1.0) offers more creative responses. Adjust this setting according to your business needs.
- Enter the API key in the designated field.
- Configure the knowledge base that the AI will use to respond to queries.
- Set up retry attempts and fallback messages for better user experience.
Once everything is configured, you can save your settings. This step is crucial as it ensures your AI assistant is ready to handle customer queries efficiently.
4. Embedding Your AI Assistant into Your Business
After configuring your AI assistant, Pabbly Connect allows you to embed it into your business website. Simply click on the “Embed” button to retrieve the script code.
This script can be pasted directly into your website’s HTML code. Once embedded, your AI assistant will be live and ready to interact with customers. This integration enhances customer engagement by providing instant responses to their inquiries.
- Copy the provided script code.
- Paste the code into your website’s HTML.
- Test the assistant to ensure it functions correctly on your site.
This simple process of embedding your assistant showcases how Pabbly Connect simplifies complex integrations into manageable tasks.
5. Enabling AI Assistant for All Contacts
To ensure that your AI assistant is available for all contacts, navigate to the settings in Pabbly Connect. Here, you can enable AI auto replies for your entire contact list.
Simply select the contact list you wish to enable the assistant for. This feature allows your customers to receive instant responses without waiting for human intervention, enhancing the overall customer experience.
- Go to the “Inbox Settings” section.
- Enable the AI auto replies option.
- Select the AI assistant you wish to enable.
Once enabled, your AI assistant will be active for all selected contacts, ensuring that queries are resolved instantly, showcasing the powerful capabilities of Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to integrate Now, API, GPD, and other tools effectively. By following these steps, you can enhance your business automation and provide instant customer support through your AI assistant.
