1. Setting Up Pabbly Connect for WhatsApp AI Agent
To create your first AI agent for WhatsApp, the first step is to access Pabbly Connect. This powerful integration platform allows you to connect various applications seamlessly. Start by logging into your Pabbly account and navigating to the Pabbly Connect dashboard.
Once in the dashboard, you will find options to create a new workflow. Click on the ‘Create Workflow’ button, and give your workflow a name that reflects its purpose. This is essential for keeping your integrations organized. After naming your workflow, proceed to set up the triggers and actions that will define how your AI agent operates.
2. Creating Your AI Agent in Pabbly Chatbot
Next, to create an AI agent, navigate to the Pabbly Chatbot section. Here, you can easily set up various AI agents tailored for WhatsApp. Click on the ‘Add AI Assistant’ button to start the process. You will be prompted to name your assistant; for this tutorial, we will call it “AI Agent”.
- Click on the ‘Add AI Assistant’ button.
- Name your assistant (e.g., “AI Agent”).
- Select the type of instruction for the AI agent.
After naming your agent, you will select the type of instructions. Choose the option labeled “AI Agent” to automatically generate the necessary instructions for your assistant. This step is crucial as it defines how the AI will respond to customer inquiries.
3. Configuring OpenAI Integration
To enhance your AI agent’s capabilities, you need to integrate OpenAI. In the configuration settings, set the AI provider to OpenAI and select the desired version, such as GPT 5.2. This version is particularly useful for responding to image-related queries.
Next, you will need to generate an API key from your OpenAI account. Go to the API keys section in OpenAI and click on ‘Create New Secret Key’. Fill in the optional fields, then click ‘Create’. This key is essential for establishing a connection between your OpenAI account and the AI agent configured in Pabbly Connect.
4. Setting Up Your Knowledge Base
The knowledge base is a critical component for your AI agent, as it provides specific information about your business. You can create this document using Google Docs or any text editor, ensuring the file size is under 90 MB. Once your knowledge base is ready, return to your Pabbly Connect setup.
- Click on ‘Add New File’ to upload your knowledge base.
- Select the knowledge base file from your device.
- Click ‘Insert’ to finalize the upload.
This knowledge base will allow your AI agent to respond accurately to customer queries, making it an essential part of the setup process.
5. Finalizing Your AI Agent and Settings
After setting up your knowledge base, you can customize the appearance of your AI agent. You can add a header message, footer message, and even adjust retry attempts for responses. Once you are satisfied with the configuration, activate your AI agent by toggling the activation switch and clicking on ‘Save AI Assistant’.
Additionally, ensure that your AI agent is correctly linked to your WhatsApp contacts. Navigate to the settings menu in Pabbly Chatbot, scroll to the automatic response settings, and enable the AI assistant for your contacts. This will allow your AI agent to respond to customer messages effectively.
In this tutorial, you learned how to create your first AI agent for WhatsApp using Pabbly Connect. By following the steps to integrate Pabbly Chatbot and OpenAI, you can enhance customer interactions effortlessly. Start building your AI agent today for seamless communication!
