To start integrating Pabbly Chatbot with WhatsApp AI, first, you need to access Pabbly Connect. Visit www.pabbly.com/chatbot to reach the Pabbly Chatbot landing page. If you are a new user, you will receive 100 free credits, allowing you to create your AI assistant without any initial cost.
After logging in, navigate to the AI assistant section within Pabbly Chatbot. This is where you will create your WhatsApp AI assistant. Make sure to complete the account setup before proceeding. If you need assistance with setup, refer to the video links provided in the description.
2. Creating Your AI Assistant Using Pabbly Chatbot
Once you’re in the AI assistant section, click on the ‘Add AI Assistant’ button. You will be prompted to name your assistant. This is crucial as it will represent your business on WhatsApp.
- Select the instruction type (AI agent).
- Configure AI settings, including temperature (set to 0.5 for balanced responses).
- Enter your OpenAI API key for integration.
After setting these parameters, you will have a functional AI assistant ready to respond to customer queries. Remember, Pabbly Connect is essential for linking your assistant with WhatsApp AI.
3. Configuring Knowledge Source for Your AI Assistant
Next, you need to configure the knowledge source for your AI assistant. This document will train your assistant on how to respond to queries. Create a comprehensive document that includes your business overview, product information, and policies.
- Upload the knowledge document in the designated section.
- Ensure the document contains all relevant information for accurate responses.
- Utilize the knowledge base to enhance your assistant’s capabilities.
Once the knowledge source is set up, your assistant will be equipped to handle various customer inquiries effectively. This is where Pabbly Connect truly shines, allowing seamless integration of your documents into the AI assistant.
4. Styling and Interface Setup for Pabbly Chatbot
The next step involves customizing the assistant’s interface to match your brand. In the assistant interface section, you can adjust the initial messages, add headers or footers, and even change the color scheme to align with your brand identity.
- Edit the business name and initial messages for personalization.
- Choose whether to enable the ‘Powered by Pabbly’ option.
- Adjust the styling to fit your website’s theme.
After completing the styling, your AI assistant will not only function effectively but also look appealing to users. This customization is made possible through Pabbly Connect, which allows you to integrate your branding seamlessly into the assistant.
5. Testing and Launching Your AI Assistant
Once your assistant is fully configured, it’s time to test its functionality. You can ask questions like, ‘Can I cancel my order after placing it?’ to see how the assistant responds. The AI should provide accurate and prompt replies, demonstrating its capability to handle customer queries.
To launch your assistant on WhatsApp, go to the settings and enable the AI auto-reply feature. Select the contacts to whom you want to assign the assistant, ensuring it can respond to all incoming queries. This is where Pabbly Connect enables you to automate customer interactions efficiently.
After enabling the assistant, you can also embed it on your website by copying the provided script and pasting it into your website’s code. This ensures that customers can access your WhatsApp support directly from your site.
In this tutorial, we explored how to integrate Pabbly Chatbot with WhatsApp AI using Pabbly Connect. By following these steps, you can create a powerful AI assistant capable of handling customer queries 24/7, enhancing your business’s efficiency and customer satisfaction.
