To start integrating Gemini AI with Google Sheets, first access Pabbly Connect. This platform is essential for automating workflows between applications. If you don’t have an account, sign up for free and receive 100 free tasks every month.
Once logged in, you can easily navigate through the dashboard. Here, you can create a new workflow to connect Google Sheets and Gemini AI. This integration will allow you to automate the process of gathering insights from YouTube videos without manual effort.
2. Setting Up Google Sheets Trigger in Pabbly Connect
The first step in this integration is to set up a trigger in Pabbly Connect using Google Sheets. You will need to create a new workflow and select Google Sheets as your trigger application. Choose the event “New Updated Spreadsheet Row” to initiate the workflow whenever you add a new video link and title.
  • Open your Google Sheets and enter the video title and link.
  • In Google Sheets, go to Extensions > Add-ons > Get Add-ons and search for “Pabbly Webhooks” to install it.
  • After installation, set up the webhook URL in the initial setup dialog box.
After completing these steps, your Google Sheets will send data to Pabbly Connect whenever a new row is updated, allowing seamless integration.
3. Connecting Gemini AI for Video Insights
Once the trigger is set, the next step is to connect Gemini AI through Pabbly Connect. This step is crucial for analyzing the video insights. Select the Google AI Studio Gemini application and choose the event for fetching video insights.
To establish the connection, you will need to provide a token from your OpenAI account. Follow these steps to generate and input the token:
  • Go to the OpenAI playground and generate your API key.
  • Paste the token in the connection field in Pabbly Connect.
  • Save the connection to proceed.
By connecting Gemini AI, you enable Pabbly Connect to fetch insights based on the video URLs you input in Google Sheets. This automation saves significant time and effort in content analysis.
4. Analyzing Video Insights and Delaying Workflow
After setting up the connection, you will send a request to analyze the video insights. In this step, you will need to customize your prompt to specify what insights you want from Gemini AI. Enter the URL and the prompt detailing your analysis requirements.
Since the analysis may take time, you can add a delay in your workflow using the “Delay by Pabbly” feature. Here’s how to do it:
  • Select “Delay” from the Pabbly Connect options.
  • Set the delay time to 10 minutes to allow for processing.
  • Save this step to continue with the workflow.
This delay ensures that you allow sufficient time for Gemini AI to process the video and return the insights needed for your content creation.
5. Updating Google Sheets with Insights
The final step involves updating your Google Sheets with the insights gathered from Gemini AI. In Pabbly Connect, select Google Sheets again as your action application and choose the event “Update Cell Value”.
Map the data from the previous steps, ensuring that the insights are accurately entered into your Google Sheets. Follow these steps:
  • Select the spreadsheet where you want to update the insights.
  • Choose the appropriate column and row index for the data.
  • Map the insights you received from Gemini AI to the designated cell.
Once you execute this step, your Google Sheets will be updated with detailed insights, completing the integration process using Pabbly Connect. Now, you can easily track and analyze competitor videos without manual effort.
In this tutorial, we explored how to integrate Gemini AI with Google Sheets using Pabbly Connect. This powerful automation allows YouTubers to gain valuable insights quickly and efficiently. By following these steps, you can streamline your content creation process and enhance your video strategies.
