To start integrating Facebook Messenger with Google Gemini, the first step is accessing Pabbly Connect. Open a new tab and navigate to www.pabbly.com/connect. This platform allows you to automate various tasks seamlessly.
If it’s your first time using Pabbly Connect, you can sign up for free, which provides you with 100 free tasks each month. This allows you to explore the features and create your workflows without any initial investment.
2. Setting Up Facebook Messenger in Pabbly Connect
Once logged into Pabbly Connect, you can begin setting up your integration. Start by creating a new workflow and selecting Facebook Messenger as your trigger application. This will initiate the process of connecting your Facebook page to Pabbly Connect.
  • Click on the “Add New Connection” button.
  • Press the “Connect with Facebook Messenger” button.
  • Follow the prompts to authorize Pabbly Connect with your Facebook account.
After connecting, select your business page from the dropdown menu. This setup allows Pabbly Connect to monitor messages sent to your page and respond automatically.
3. Generating Responses Using Google Gemini
Next, you will set up Google Gemini to generate automated responses to inquiries received via Facebook Messenger. In this step, Pabbly Connect acts as the intermediary that facilitates communication between Facebook Messenger and Google Gemini.
To integrate Gemini, click on the “Add New Connection” option again and select Google Gemini. You will need to enter your API key, which can be obtained from the Gemini API keys page.
  • Navigate to the Gemini API keys page and generate your API key.
  • Copy the API key and paste it into the designated field in Pabbly Connect.
  • Map the input data from Facebook Messenger to the prompt field in Gemini.
This mapping allows Gemini to understand the context of the inquiry and generate an appropriate response.
4. Sending Responses Back to Facebook Messenger
After generating a response with Google Gemini, the next step is to send that response back to the user on Facebook Messenger. This is where Pabbly Connect streamlines the process, ensuring that the generated replies reach the right audience.
To do this, select the action to send a message back to Facebook Messenger. You will need to map the recipient ID, page ID, and the message generated by Gemini.
  • Map the recipient ID from the previous response step.
  • Map the page ID to ensure the message goes to the correct Facebook page.
  • Finally, map the message generated by Google Gemini.
Once everything is mapped, click the “Save and Send Test Request” button to complete the integration. This action will send the generated response back to the user who inquired.
5. Conclusion: Automate Your Facebook Messenger Responses
By following the steps outlined above, you can effectively automate responses to inquiries on Facebook Messenger using Pabbly Connect and Google Gemini. This integration enhances your customer service capabilities and ensures that no lead goes unanswered.
With Pabbly Connect, you can manage multiple automations seamlessly, allowing you to focus on growing your business while maintaining excellent communication with your clients.
