To integrate WhatsApp with Pabbly Connect, you first need to access the Pabbly Connect platform. Start by navigating to the official Pabbly website.
Once there, you will see options for signing in or signing up. If you are a new user, click on ‘Sign Up Free’ to create an account. Existing users can simply sign in. This is your first step towards using Pabbly Connect for WhatsApp integration.
2. Connecting WhatsApp to Pabbly Connect
After logging into your Pabbly Connect account, the next step is to connect your WhatsApp account. This integration allows you to automate responses and manage customer queries effectively.
- Click on ‘Access Now’ under Pabbly Chatflow.
- Go to the dashboard and find the option to connect your WhatsApp number.
- Follow the prompts to authenticate and link your WhatsApp account.
This process ensures that your WhatsApp account is ready for integration with Pabbly Connect, allowing you to automate communication seamlessly.
3. Creating an AI Chatbot with Pabbly Connect
Now that your WhatsApp is connected, you can create an AI chatbot using Pabbly Connect. This feature enables your chatbot to respond automatically to customer inquiries.
To start creating your AI chatbot, click on the ‘Add’ button. You will be directed to a flow window where you can define the chatbot’s instructions. Choose the instruction type from the dropdown menu.
- Select ‘AI Agent’ as the instruction type.
- Configure the AI settings, including temperature and model selection.
- Input your API key to connect the AI model.
This setup allows your chatbot to provide quick responses based on the queries received on WhatsApp, enhancing customer interaction.
4. Finalizing Your Chatbot Settings
After setting up the AI chatbot, you need to finalize its settings in Pabbly Connect. This includes customizing messages, headers, and footer texts.
In the assistant settings, you can add a header message up to 60 characters. Additionally, you can set keywords that will trigger the assistant to stop responding, ensuring that human intervention is possible.
- Add a fallback message for when the AI fails to respond correctly.
- Specify the knowledge source for accurate responses.
- Download the knowledge document in plain text format.
This comprehensive setup ensures that your WhatsApp AI chatbot is effective and user-friendly, providing a seamless experience for your customers.
5. Assigning Your Chatbot to WhatsApp Chats
Finally, to make your AI chatbot operational, you need to assign it to your WhatsApp chats using Pabbly Connect. This step is crucial for automating responses.
Navigate to the inbox settings and scroll down to find the AI auto-reply settings. Enable the auto-reply feature and select the assistant you created earlier.
- Assign the assistant to your contact list for bulk assignments.
- For individual chats, select the specific chat and assign the assistant.
By completing this assignment, your WhatsApp AI chatbot is now ready to handle customer queries automatically, enhancing your business operations.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect, creating an AI chatbot that automates customer interactions. By following these steps, you can enhance your business communication effectively.
