1. Accessing Pabbly Connect for Image Generation
To start generating unlimited AI images, first, access Pabbly Connect. Open a new tab and type ‘pabbly.com/connect’ in your browser. This will take you to the Pabbly Connect landing page.
If you’re a new user, click on the ‘Sign Up for Free’ button to create an account. Existing users should click ‘Sign In’ to access their dashboards. Pabbly Connect offers 100 free tasks every month, making it a great choice for automating your workflows.
After signing in, you’ll be directed to your dashboard in Pabbly Connect. Here, you can create a new workflow to automate AI image generation. Click on the ‘Create Workflow’ button to begin.
  • Name your workflow, e.g., ‘Generate AI Images’.
  • Set the trigger event to ‘New Row’.
Once you have named your workflow and set the trigger, click on ‘Save and Continue’. This will set up the initial steps for your automation.
3. Connecting Google Sheets with Pabbly Connect
Next, you need to connect Google Sheets to Pabbly Connect. This will allow you to input prompts for the AI image generation. After selecting Google Sheets as your trigger, you need to authorize access.
Copy the Webhook URL provided by Pabbly Connect. Then, go to your Google Sheet, click on ‘Extensions’, select ‘Pabbly Connect Webhook’, and choose ‘Initial Setup’. Paste the copied Webhook URL into the designated field and select the trigger column, which is typically the last updated column in your sheet.
4. Generating AI Images Using Google AI
With Google Sheets connected to Pabbly Connect, you can now set up the action to generate images using Google AI. Choose Google AI as the action application and select the desired model for image generation.
  • Select the API key for Google AI.
  • Map the prompt details from Google Sheets to the respective fields in the Google AI setup.
  • Specify the output format and resolution for the generated images.
Once configured, click on ‘Save and Send Test Request’ to generate the AI image based on the prompt provided in your Google Sheet.
5. Updating Google Sheets with Image URLs
Finally, to complete the workflow, you need to update your Google Sheet with the URLs of the generated images. Reconnect to Google Sheets in Pabbly Connect and select the same sheet.
Specify the column where you want to insert the image URLs. Use the mapping feature to ensure that the correct data from the previous step is inserted into the designated cell. Once everything is set, click on ‘Save’ to finalize your workflow.
By following this tutorial, you can effortlessly generate unlimited AI images using Pabbly Connect. This automation allows you to save time and streamline your image generation process.
