1. Accessing Pabbly Connect for Social Media Automation
To begin automating your social media posts, you need to access Pabbly Connect. Start by visiting pabby.com/connect in your browser. This will take you to the homepage of Pabbly Connect, where you can either sign up for free or log in if you are an existing user.
If you’re new, click on “Sign Up for Free” to get started with 300 free tasks every month. Existing users can simply sign in. Pabbly Connect provides an amazing way to automate your social media posting process, ensuring you never miss a post again.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you need to create a new workflow to set up your automation. Click on the “Access Now” button to get started. You’ll find multiple methods to build your workflow, but we will use the Quick Builder for this tutorial.
  • Select “Quick Builder” to create your workflow.
  • Choose your trigger and action settings.
  • Set the frequency of your automation.
After setting up your workflow, you’ll need to define the trigger and action. The trigger indicates when the automation should run, while the action specifies what should happen. This is where Pabbly Connect shines, allowing you to automate tasks seamlessly.
For this automation, we want to run the workflow daily at a specific time. In the trigger settings, select the option for “Every Day” and set the time to 12:00 PM. Click “Save” to confirm your settings. This means your automation will now run every day at noon, generating content for your social media posts.
Next, we will integrate an AI tool to generate the content. You can use tools like Gemini, OpenAI, or Perplexity AI. Here, select the AI tool and input your API key. If you don’t have an API key, you can create one by navigating to your Google AI studio account.
  • Log into your Google AI studio account.
  • Click on “Get API Key” to generate a new key.
  • Use the generated key in Pabbly Connect for the AI tool.
Once you have successfully connected the AI tool, you can input the prompt for generating your social media post content. This setup allows Pabbly Connect to automate the content generation process smoothly.
4. Posting Generated Content to Facebook and LinkedIn
After generating the content, the next step is to post it on your Facebook page. In Pabbly Connect, create a new connection and select “Connect with Facebook Pages”. Choose your desired Facebook account and grant access to Pabbly Connect to post on your behalf.
For the message field, map the content generated by the AI tool. This mapping allows the content to dynamically update with each new post. You can leave the link URL blank if not needed. Click on “Save and Send Test Request” to share the post on your Facebook page.
  • Select your Facebook page from the dropdown.
  • Map the AI-generated content to the post message.
  • Click “Save and Send Test Request” to publish.
Once the post is successfully shared on Facebook, you can repeat the process to share the same content on your LinkedIn account. This allows you to reach a broader audience with minimal effort, thanks to Pabbly Connect.
5. Summary of the Automation Process with Pabbly Connect
To summarize, we set up a daily automation using Pabbly Connect that generates social media post content through an AI tool and shares it on both Facebook and LinkedIn. The entire process involves configuring triggers, connecting to AI for content generation, and mapping the generated content to social media posts.
This automation not only saves time but also ensures consistent posting on your social media platforms. By leveraging Pabbly Connect, you can streamline your digital marketing efforts effectively.
Now you have a complete guide on how to automate your social media posts using Pabbly Connect. Implement these steps to enhance your social media presence effortlessly.
Automating social media posts with Pabbly Connect saves time and ensures consistent content delivery. By following this tutorial, you can integrate AI-generated content seamlessly with your Facebook and LinkedIn accounts.
