To begin the integration process, you need to access Pabbly Connect. This platform allows you to connect various applications seamlessly. Open a new tab in your browser and type “Pabbly.com/connect” to reach the Pabbly Connect landing page.
If you are a new user, click on the “Sign Up for Free” button to create an account. Existing users should click on “Sign In”. After signing in, you’ll be taken to the Pabbly Connect dashboard, where you can manage your integrations and workflows.
Once you are in the Pabbly Connect dashboard, you can create a new workflow. Click on the “Create Workflow” button. This will allow you to set up the automation process for generating marketing images.
- Click on “Create Workflow”.
- Name your workflow (e.g., “Google Sheets to Google Air Stud”).
- Click “Enter” to accept the command.
Your workflow will now be set up to trigger whenever a new row is added to your Google Sheet. This is where Pabbly Connect facilitates the connection between Google Sheets and Google Air Stud.
3. Connecting Google Sheets and Google Air Stud via Pabbly Connect
Next, you will connect Google Sheets to Pabbly Connect using a webhook URL. This URL acts as a bridge between the two applications. Copy the webhook URL provided by Pabbly Connect and navigate to your Google Sheet.
In your Google Sheet, go to “Extensions” > “Add-Ons” > “Get Add-Ons” and search for “Pabbly Connect”. Install it if you haven’t already. After installation, go back to “Extensions” and select “Pabbly Connect” to set up the initial configuration.
4. Generating Images Using Google Air Stud
After connecting Google Sheets, set up the integration with Google Air Stud through Pabbly Connect. This requires you to generate an API key from Google Air Stud. Click on “Get API Key” and copy it to use in Pabbly Connect.
- Select the model (e.g., “Nano” or “Pro”).
- Choose the method “Generate Content”.
- Map the image idea from Google Sheets to the prompt in Google Air Stud.
This mapping is crucial as it allows the generated images to be based on the topics you input in your Google Sheet. Once set up, you can test the integration and see the generated images appear in your Google Sheet.
5. Bulk Image Generation and Final Steps
If you want to generate images for multiple topics in bulk, simply delete any previously generated images in your Google Sheet. Then, add all your topics in the sheet and click on “Send All Data” in the Pabbly Connect add-on. This will trigger the workflow for each topic in a single click.
The integration via Pabbly Connect ensures that each image is generated and added next to its corresponding topic automatically. This automation saves time and effort, making marketing image creation efficient.
In this tutorial, we explored how to automate marketing image generation using Pabbly Connect and Google Air Stud. By following the steps outlined, you can streamline your workflow and enhance productivity.
